07-26-2010, 11:30 AM | #1 |
Rep 3,465
Drives: 997.2 GT3, '17 G30
Will these fit?
18x8.5 ET38 front
18x9 ET45 rear Also what size tiress are recommended for such a set-up that is not terribly stretch nor will rub (I wouldn't mind rolling fenders). According to 1010tires, for front = inner clearance is 2mm less so that means add a 5mm spacer? Outer clearance is extend 24mm. Rear = inner clearance is 1mm more (no spacer?) Outer clearance is extend 13mm. Any help or advice is appreciated.
ig: 0verrev
07-26-2010, 11:51 AM | #2 |
Rep 4,528
Drives: M2 CS
they will fit, no need for a spacer
225/255 should work fine. maybe a lil rolling in the rear |
