07-20-2010, 11:24 PM | #1 |
Rep 32
I installed my WeissLicht Angel Eyes today please help!
i ordered a set of WeissLicht Angel Eyes from http://www.bimmian.com/ and i installed them but i cant get them to lock into place they just wiggle around. does any one have experience with this. please help
07-20-2010, 11:56 PM | #2 |
Rep 1,036
most probably one of the locking clips (bulb stem) is too big for it to fit. try to cut some of it using pliers and you'll be good to go!
F13 ///M6 SMB/SO
E92 ///M3 AW/FR- Sold E92 335i MB/BLK- Sold [IMG]http://www.bimmerpost.com/forums/attachment.php?attachmentid=133578 |
07-21-2010, 12:04 AM | #3 |
Rep 686
07-21-2010, 01:01 AM | #4 |
Rep 18
Same thing happened to me
It would appear as though they do not lock into place. They do not snug up like the h8 bulb and this is with the tabs inserted (they do fit). What I did to rectify this problem was to cut a bit of the rubber gasket off the old h8 bulb and sandwich it between the gasket on the weisslicht bulb and the housing. This allowed me to snug the light down and now it does not move at all. It will also allow you to tweak the lights so that they are shining right into the fiber optic loops. I totally agree that you should not have to do this, but I really did not want to send it back and it was an easy fix. Whoever is producing these needs to pull their head and make sure these things snug down when rotated into position.
08-03-2010, 06:09 PM | #6 |
Rep 9
weisslicht angel eyes install review
I have exactly the same issue as they are pretty loosen after install. And then I found out the rubber washer/gasket from the OEM bulb is a bit thicker than the one from Weisslicht. I simply EXCHANGE them and they are alot tighter now.
Also the orientation of the passenger side bulb is not quite correct according to their pdf file, I had to change the screws around so the LEDs point directly to the holes in the cup. |
08-03-2010, 08:45 PM | #7 | |
Naval Aviator
596
Rep 676
e92 M3 - Interlagos Blue | Fox Red Extended |Carbon Leather
Performance Mods: Alpine Stage II E85; SuperSprint F1s; Cat-less Bomiz X-Pipe; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK |
08-03-2010, 09:44 PM | #8 | |
Rep 1,769
Drives: 2011 E92 M3 ZCP
I would have kept the lights and disputed the charge on my AMEX. I have no patience or tolerance for people that do business that way.
'12 CLS550 Palladium Silver - loaded
'11 E92 M3 ZCP - SG/B-EXT/CF, M-DCT, loaded '11 E93 328i, BSM over Saddle Brown, sport, loaded '08 550i M-Sport, Carbon Black (Gone but not forgotten), '06 W211 E55 AMG (Gone, miss this animal),'01 E39 540i Sport |
