05-20-2010, 11:49 PM | #1 |
Rep 208
For Those Who Have Removed Tint - How Did It Go?
Need to get tint on 3 rear windows removed. Quite nervous about it given possibility of antenna or defroster damage apart from general interior wear and damage from the removal process. Also don't want residual, visible glue left behind.
I know most tint shops also don't enjoy the removal process. It is hard work. For those that have done it before - how have your experiences been? Did your car come back as if the tint was never there, or did anything go wrong? Thanks! |
05-21-2010, 12:40 AM | #2 | |
Rep 469
Drives: X5 50iMSport & MP4-12C
2012 McLaren MP4-12C
2015 BMW X5 50i MSport 2017 BMW M2 (on order) |
05-21-2010, 01:03 AM | #3 | |
Rep 208
Removing it because prior owner had no idea what he was doing and installed bad tint by a bad installer. Don't like the way tint looks, either. It just needs to go. Goal is to get factory look back. |
05-21-2010, 02:25 AM | #4 |
8 tracks of madness
62
Rep 2,735
Side windows are cake. Rear window, don't be surprised if you lose a defroster line or two. I pulled the tint on my old Passat wagon and I only barely nicked 2 lines.
05-21-2010, 07:59 AM | #5 |
Rep 19
I had tint removed from my VW and the shop I went to in SF did a very good job. None of my defrosters got damaged. The only thing I was unhappy about, was they left a tiny nick on my driver side door panel from the tool they were using to remove. The tint was on my car for 6 years! Which shop are you going to?
05-21-2010, 08:38 AM | #6 |
Rep 3,329
I removed my tint myself... I took a spray bottle of soap water and a blow dryer and heated one edge so that i can easily peel it off then i took the spray bottle and soaked the area that i was pulling from... You must constantly wet it. I did not damage any defroster lines at all. The i took alcohol/soap water and cleaned off the remaining glue
F80 ///M3 6MT Avus Blue ZCP |
05-21-2010, 08:45 AM | #7 | |
Rep 3,329
05-21-2010, 08:46 AM | #8 |
Rep 3,173
my suggestion based on regrets...take it to a tint shop to be done...it is a PIA and you will regret not spending the money to have it done vs doing it yourself
05-21-2010, 08:49 AM | #9 |
Rep 2,528
You should not lose ANY defroster lines if you deal with a pro. Here is my best advice from when I changed my tint. Go to the dealer and have their mechanics remove your rear deck. It makes the adhesive removal process much easier on the tint shop and allows the new tint to lay closer to the rear of the car.
05-21-2010, 10:56 AM | #10 |
Rep 208
Thanks for all the responses. I am not laying down new tint - in some ways that would make things look better, could hide the previous adhesive. I don't like the tinted look so am taking it off once and for all.
I have no intention of doing this myself. Am taking it to a pro, but wondering if I have any options. The tint guy who said it would be super hard actually suggested perhaps replacing the entire rear glass. I'd rather not do that - hate breaking factory seals - but am wondering if that might be better than having a guy spend a couple hours kneeing my interior and risking damage to the interior. Cost is not an issue here...just want a brand new OEM look. For the record, the one who said it would be straightforward seems kinda gruff and am not sure he will put in all the time necessary. The comment about having the dealership remove the rear decklid is not a bad one. I am honestly not thrilled about removing or disassembling anything on the car though. |
05-21-2010, 11:01 AM | #11 |
Rep 55
Side windows are very easy to remove. Leave your vehicle outside in the sun when it's really hot. PIA is when it's come to rear windshield. Either way, Replacing windows doesn't sound right even If cost isn't an issue.
05-21-2010, 11:49 AM | #12 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
Pretty easy...did it myself...
05-21-2010, 09:47 PM | #13 |
Rep 83
Seems like I remember when I got my tint installed the guy said they don't use adhesive anymore. just water. Could be wrong though.
2010 M3 Coupe - Jet Black on black interior /// Escort 9500ci /// Macht Schnell - Stage 1 Intake Charge Kit /// DEPO Smoked Front Reflectors /// Black Satin Chrome Edition front/side grills |
05-22-2010, 12:12 PM | #14 | |
Rep 208
I am sure they did. Perhaps the adhesive was pre-attached, but I am sure it was there. I haven't heard any horror stories yet regarding removal. It sounds like it can be done, safely, but a PERFECT job seems hard to do. |
05-22-2010, 12:13 PM | #15 |
Rep 208
05-22-2010, 02:46 PM | #16 | |
Rep 2,736
If you go real slow the glue will stick on the tint, and not the window. This is especially crucial for the rear window because you don't want to be scraping around the defroster with a razor blade...for the side windows its not a big deal, just spray with some alc and shave off the glue with a blade... Didn't have to remove anything...
05-22-2010, 08:47 PM | #17 | |
Rep 208
06-02-2010, 09:36 PM | #19 |
Rep 70
OP, I get my tint done through Sidney Lee at Auto Mall Tint Specialist in Fremont. I think he's the best in the bay area at this, excellent attention to detail and absolutely stands by his work.
He'll likely tell you the same thing about the rear window--that's just how it is. But he's a perfectionist and he knows what he is doing. Good luck.
revster :: 08 e90 M3 jerez/black/carbon
06-02-2010, 10:51 PM | #20 | |
Rep 208
My top priority is making sure that the job gets done right. |
08-02-2010, 11:05 PM | #21 | |
Rep 25
goo gone
