BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
Mporium BMW
      05-16-2010, 12:26 PM   #1
kloh
kloh's Avatar
Drives: 2009 E92 M3
2009 E92 M3  [0.00]
Goof Off, Goo Gone or Eraser Pad?
I just ordered the ZCP Spoiler from Tischer so which product do you guys think is best to clean off the gunk from the old spoiler?
ED Vehicle: 2009 E92 M3 6MT | Space Gray, Fox Red Ext, Carbon Leather | Mod Progress: Flickr Photos
ED Tour: Aug 3 - Aug 10 2009. (Trip Blog | Route map).
ED Progress: Delivery Aug 4th; Drop off at Frankfurt Aug 10th; Redelivery Oct 9th.
      05-16-2010, 01:34 PM   #2
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
ive been using goo gone for everything.. double sided tape stains, sticker marks on glass, etc.. worked great with no problems for me.
      05-18-2010, 09:35 PM   #3
kloh
kloh's Avatar
Drives: 2009 E92 M3
2009 E92 M3  [0.00]
anyone else care to share your experiences?
@omid_inc did you use the spray or gel?
      05-18-2010, 10:13 PM   #4
Martin_D
Martin_D's Avatar
Drives: Ford Super Duty
3M Tar and Adhesive Remover is the best, and safest to use on paint
      05-18-2010, 10:52 PM   #5
FruitCake
Taiwan
88
Drives: '10 E92 M3
that is not bad but hard to locate. go to your local auto parts store and just get some goo-gone and some wd-40.
use all in moderation and patience, its not rocket science.
      05-19-2010, 08:05 AM   #6
Martin_D
Martin_D's Avatar
WalMart carries it.
      05-19-2010, 01:59 PM   #7
quality_sound
8 tracks of madness
Drives: Slowly
I wouldn't use ANY adhesive remover. It's going to turn the tape into a goopy, sticky, wet mess. Since you're going to have to polish the area anyway the best thing I've found is to use my thumb or my fingernail. Yes, you're going to mar the area a little bit but even a mild polish will remove that and you're good to go.
And don't use WD-40. WD-40 is a water displacer not a lubricant nor an adhesive remover. Gasoline is a much better adhesive remover it just has the downside of being toxic and flammable.
      05-19-2010, 02:34 PM   #8
kloh
kloh's Avatar
Drives: 2009 E92 M3
2009 E92 M3  [0.00]
LOL...I've been using my thumb and fingernail up until now as well (for debadging and whatnot). Just wanted to go with something quicker this time around to avoid the blisters since I'm assuming this will be a fairly large area to deal with.
      05-19-2010, 03:48 PM   #9
RENN Spec
Drives: 488 Pista, M2CS, Tundra
Don't ever use the eraser pad on paint. That stuff is abrasive and will ruin the finish.
      05-19-2010, 04:15 PM   #10
Martin_D
Martin_D's Avatar
Coming from someone that has removed hundreds of clear bras for customers use adhesive remover. That "goop" you speak of can be wiped away with EASE compared to the crap left behind using gas.
      05-19-2010, 04:46 PM   #11
kloh
kloh's Avatar
Drives: 2009 E92 M3
2009 E92 M3  [0.00]
This is what I was worried about but it seemed like the product was made for this type of application so I was wondering if any forum members had experience with it. Thanks for the insight.
      05-19-2010, 05:12 PM   #12
audioMeth
BTC maxi
audioMeth's Avatar
Drives: F80
i use goo gone gel. works very well and quickly. just clean and clay the area after if you're worried.
      05-19-2010, 11:03 PM   #13
quality_sound
8 tracks of madness
Drives: Slowly
IME gas and Goo Gone/Goof Off turn the tape into the same crap but gas is MUCH easier to remove from the paint. Goo Gone/Goof Off residue is a PITA to remove.
      05-20-2010, 02:24 AM   #14
Lagunae92
Drives: BMW e92 M3 Laguna Seca Blue
I've used the Magic Eraser on a couple of small spots for paint transfer. Worked PERFECTLY! Amazing, but I was worried about the finish...seems okay though.
      05-25-2010, 03:24 PM   #15
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
goo gone
m3post
