BMW M3 Forum (E90 E92)
BPM
      08-26-2009, 07:15 PM   #1
wolftrouble
Drives: 2008 M3 Sedan
Lift cup DIY?
Ok, so this is a weird one.
While working on my M a few weeks back, a jack stand bit through one of the plastic lift point cups. I picked up a new one from the dealer for pretty cheap (for a BMW part), but looking at it, I have no idea how to actually put it in.
The problem is that it's held in by a couple of tabs that are quite a ways in, and I can't think of a single tool that would fit in there with enough leverage to push in the existing one.
Anyone replaced these before? Any suggestions on how to do it?
      08-28-2009, 02:34 PM   #2
M3ltdown
Master Chief
M3ltdown's Avatar
Drives: 09 e90 M3 JzB
free bump for.... since i also need one of those lifts replaced
      08-28-2009, 06:00 PM   #3
ff1600
Drives: 2018 F80 M3 CP 6mt YMB/SB
I just used a small flat blade screw driver. Do one end then the other. I then put some weight on it with the floor jack to be sure it is fully seated.
I use this to avoid damage to the jack pad
http://www.ecstuning.com/Search/Jack...pter/ES251251/
      08-28-2009, 09:09 PM   #4
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
wait , i think he is trying to take the existing one out
      08-28-2009, 10:24 PM   #5
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
I think he's saying you pry it out with a screwdriver. Then seat the new one with weight applied.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      08-28-2009, 11:58 PM   #6
ff1600
Yes, use a small screw driver to push the the locking tabs free (one at each end) in order to remove the jack pad. Sorry, I wasn't very clear on that.
      09-02-2009, 12:56 PM   #7
wolftrouble
No joy, and to be honest, I have no clue how you did it. Was this on an E9X? I assume it was, but on my E90, all four cup mount-points are 'countersunk' beneath the undercarriage protector (the felt-covered thing), and right next to the under-door body panel. There's absolutely no way to get a screwdriver at better than a 45-degree angle into where the cup meets the mount point because of this. The gap to the side is too small to even fit a right-angle tool (I was going to maybe try to use a right-angle trim tool) with any leverage.
In short, I can't see how it can be done without removing the undercarriage piece (which I'm not even sure is possibly, it looks riveted on).
      09-02-2009, 03:02 PM   #8
M3ltdown
Master Chief
M3ltdown's Avatar
Yeah... I had the same problem on my e90. The felt undercover prevents any use of a screwdriver to push the tab in. I'm sure there is a way to remove that felt lining but I just haven't had a chance to look at it yet. I guess I could drive the M3 up my rhino ramp and see how to do it.
      09-10-2009, 10:02 PM   #9
lucid
lucid's Avatar
Drives: E30 M3; Expedition
Yes, I also don't get this. Can someone clarify (with pic if possible) please?
      10-05-2009, 10:14 PM   #10
JuniorDee
JuniorDee's Avatar
74
Drives: the speed limit
I posted a while back that I jacked the hell out of my jack points. I bought 4 new ones and replaced the old ones.
I put the car on ramps and drilled out the old ones. since i did not take any photos of the process, here is what i can tell you. Order the replacement pads. After you get the new ones you will see that with the right sized drill bit you can drill in on an angle and drill out the retaining clips. I drilled out the clips and hit at the old pad with a hammer to get it off. I know it all sounds very brute force-ish, but its really the only way. I may still have the old pads that I drilled out. Let me look. If I still have them I will post photos of the drill holes. Oh by the way the pads mound right into the steel frame, and if you use the right size bit you will not even hit the steel surrounding.
EDC.....viagra for your car
      10-06-2009, 12:03 PM   #11
JCtx
Drives: No BMW yet
How did you attach them?
      11-21-2009, 10:36 AM   #12
lucid
lucid's Avatar
That would be great. Thanks!
      03-31-2011, 01:20 AM   #13
isugoo
isugoo's Avatar
Drives: 991.2 GTS
how much did you guys pay for all 4 pads?
My buddy with E92 335i got all 4 for 48 after tax and I paid 60+ tax for my E90M3 from same dealer.
I'm wondering if I got ripped off or not.
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3
m3post
