      07-28-2009, 01:41 AM   #1
bfi2906
Australia
35
Drives: 135 Coupe
Rattle
I know this has been mentioned elsewhere, but i can't find anything conclusive.
When I turn my car off, without the clutch depressed, there's a terrible rattling sound comes from the engine bay. It sounds mechanical, not plastic.
If I depress the clutch and turn it off, there's no noise.
Anyone got any ideas?
      07-28-2009, 01:54 AM   #2
Gumball
Gumball's Avatar
Australia
12
Drives: A45
Its normal - dont worry...
      07-28-2009, 02:06 AM   #3
bfi2906
Australia
35
Drives: 135 Coupe
Thanks for quick reply.
Any idea what it is? It certainly doesn't sound very healthy.
      07-28-2009, 02:27 AM   #4
TimMc
TimMc's Avatar
Australia
44
Drives: E90 M3
Probably the gearbox. The Getrag box rattles unless it's under load. Depressing the clutch pedal disengages the gearbox from the engine. You should hear the gearbox rattle coming from an idling M3 with big cams!
Driving - Manual E90 M3 (Melbourne Red/Black).
Riding - BMW R1200RS Sport.
      07-28-2009, 03:42 AM   #5
Gumball
Gumball's Avatar
Australia
12
Drives: A45
I think its the dual mass flywheel
      07-28-2009, 05:24 AM   #6
Guran
Guran's Avatar
Australia
24
Drives: 08 135i Coupe
If it's normal, why don't I hear this rattle on my car? Not that I'm complaining!
08 BMW 135i Sport Coupe | Manual | Sparkling Graphite | Coral Red Boston Leather | 10 Speaker Hi Fi
      07-28-2009, 05:56 PM   #7
dk130i
Drives: Blue car
Depending on how loud the noise is, as someone mentioned getrag gearboxes have some "rollover noise" and is quite normal.
If you think the noise is excessive it could be your clutch/flywheel.
130i models were known to have a problem with noisy clutch/flywheel. Mine was replaced under warranty.
One of the symptoms was the rattly noise when turning engine off as you described it.
On my car the noise was the worst with clutch depressed half way and disappearing completely once clutch depressed fully.
      07-28-2009, 07:46 PM   #8
Gumball
Gumball's Avatar
Australia
12
Drives: A45
I read somewhere else that its mentioned in the manual to turn the car off with the clutch pushed in.
      07-28-2009, 09:26 PM   #9
penny
penny's Avatar
Drives: '08 135i (sold)
Yeah, you're suppose to turn it off with clutch depressed. I also read it in the manual.
'08 135i.
      07-29-2009, 01:39 AM   #10
takahashi
Retired trackie
takahashi's Avatar
Australia
36
Drives: 1///M
Clutch bearing, trust bearing.... what is that called? It is common for many manual cars.
TAKA 一仔BLOGブログ:
BMW 1 series M 2011! Delivered 18/11/11.
      07-29-2009, 04:57 AM   #11
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Thats all it is..Taka is correct..Clutch release bearing.. As all have said, can be eliminated by depressing the clutch before turning off..
All this said, like Guran, mine doesnt have this noise/rattle eother..
      07-29-2009, 08:57 AM   #12
takahashi
Retired trackie
takahashi's Avatar
Australia
36
Drives: 1///M
Thanks . Lurking car forum sites for years actually will learn something.
TAKA 一仔BLOGブログ:
      07-29-2009, 07:25 PM   #13
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
My LJ GTR-XU1 had the same clutch bearing rattle back in 1979...
Amazing with all the technology, 30 years on, that some things never change..
      07-30-2009, 12:58 AM   #14
TimMc
TimMc's Avatar
Australia
44
Drives: E90 M3
Clutch throw out bearing I think we used to call it. I replaced one on a 5spd 323i some years ago.
      07-30-2009, 01:30 AM   #15
bfi2906
Australia
35
Drives: 135 Coupe
Thanks folks for putting my mind at rest that the gearbox isn't going to fall out of my car - I was starting to wonder...
It seems we have a concencus over what is causing the noise. What still has me curious is - how come not everyone with a manual gearbox seems to have the noise?
Maybe this is like the bonnet insulation - some get it - some don't. And there's no clear pattern.
Maybe there was a "Gearbox Rattle Delete" option that I should have selected when I orderes the car.
1addicts
