BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      05-21-2009, 09:42 AM   #1
BarryC
Drives: '15 M3
will 285/35 and 305/35 work on TR Motorsport 18x10?
Hi all,
looking for tires to go on my TR Motorsport rims (18x10 25et) and am considering the Nitto NT555II in the 285/35/18 and 305/35/18 sizes. This setup is close to stock in terms of overall height thus my interest. I'm also running eibach pro springs and dinan camber plates with approx. 2 degrees of negative camber.
Any thoughts?
BC
'15 M3, '16 911 Turbo S Cab
      05-21-2009, 12:29 PM   #2
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
I think a 10.5" wide wheel will work better with a 305 rear. I'd consider going with a square setup.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      05-21-2009, 05:01 PM   #3
lucid
lucid's Avatar
Drives: E30 M3; Expedition
305mm on a 10" rim seems too much...
      05-22-2009, 10:04 AM   #4
attila
attila's Avatar
83
Drives: 2015 Mclaren 650s, 2015 GTS4,
305 on a 10" rim is just too much, most likely will not even fit at all. The max is 285 I would recommend. I do run 285 on a 10"rim but was thinking even that is too much. You don't want to aproach the theoretical limit of the rim, rather choose a tire which is realatively small for the rim. You will not put that much more rubber down anyway. 305 on 10" is not the same than 305 on a 11" rim as contact patch concern. I would definately shy away to overtire my rims on the front. Your steering will not love it.
      05-22-2009, 03:38 PM   #5
BarryC
Drives: '15 M3
Thanks guys - looks like I'll go with 275/35 on all four corners...
BC
      05-22-2009, 04:15 PM   #6
lucid
lucid's Avatar
BC
There you go. That is pretty much the ideal tire size for a 10" rim. Turner runs the 275mm tire and 10" rim square setup on his M3.
m3post
