      04-16-2009, 09:21 PM   #1
dkommor
Mindful
dkommor's Avatar
Drives: 2009 128 Coupe AW
Reverse Gear Gripe
I absolutely love this car! My only complaint is the adjacent position of reverse and 1st gear on the manual trans. I'm used to reverse being in the extreme right and down position and the proximity to first gear on this car has caused me some problems. Any thoughts on the subject?
      04-16-2009, 09:25 PM   #2
yandy
yandy's Avatar
Drives: 2009 e92 MR "Civic" ///M3
2009 BMW M3  [0.00]
no concern here, I actually prefer it over the "push down then forward towards 1st" that some other have with 6MTs. Reverse is rough and tough to get to. Confusing it with 1st is really difficult in my opinion.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
      04-16-2009, 09:29 PM   #3
TimMc
TimMc's Avatar
Australia
44
Drives: E90 M3
I've driven manual BMs for years (including at the track), and never had an issue. The shift into the reverse plane requires a concerted effort that differs from all forward gears. You'll get used to it - just like I have with the indicator stalk being on the "wrong" (left) side of the steering column over here.
Driving - Manual E90 M3 (Melbourne Red/Black).
Riding - BMW R1200RS Sport.
      04-16-2009, 09:38 PM   #4
RootCanal05
Clutch Rider
RootCanal05's Avatar
11
Drives: 335i xDrive M-Sport
You'll definitely get used to it. However, I'd prefer some kind of lock out like what subaru has only because this weekend I let someone drive my car and they almost put my 1er through the garage door thinking they were in 1st. Their test drive was over real fast after that.
RootCanal-
      04-17-2009, 07:29 AM   #5
dkommor
Mindful
dkommor's Avatar
Thanks
Based upon your name, I'm hoping that you are a Dentist and not a masochist. Have a great day!
      04-17-2009, 12:37 PM   #6
2AD Tanker
Drives: 135i Black Sapphire Metallic
I prefer the upper left reverse over the lower right. Putting it in reverse and first are two different distinct movements and shouldn't be confused if one is paying attention.
      04-17-2009, 01:05 PM   #7
pit1
Drives: F87 M2
I prefer it over any other setup. It requires a very deliberate action, most 1st timers are hesitant to break it, do it once and you'll never mistake it for 1st.
Push down/Pull Up like VWs and Saab respectively are ok but they're more prone failed engagement, and I don't feel the affordance is clear enough. In our Jetta, I'm always a uncertain what gear I'm in and if R actually engaged.
Down(back) and right is my least favorite, they're simply too far apart. R-1st is the most common sequential combination...keeping them close speeds things up, especially if time is of the essence.
      04-17-2009, 01:25 PM   #8
cagekicker
cagekicker's Avatar
Drives: '09 crimson red 135i
that is european style. you must be coming from a rice burner.
6MT/ Sport Package/ N54/ Asa wheels/ Eibach pro kit springs/ Active autowerke Exhaust/ 35% tint
      04-17-2009, 02:24 PM   #9
TP 135i
TP 135i's Avatar
Drives: 2008 135i SGM MT
You'll get used to it.........but....
When I first got mine there were like 3 times that I put it in reverse at a red light and almost went backwards on the green light.
Can you say...."boy did I feel stupid"
After the first week or two, never again was that error made.
2008 135i SGM
      04-17-2009, 07:15 PM   #10
dkommor
Mindful
dkommor's Avatar
Porsche Cayman? A rice burner??
      04-17-2009, 07:46 PM   #11
lo-tek
I'm a PC
Drives: 2012 135i M-Sport Coupe
in some circles
      04-18-2009, 12:34 AM   #12
Tj303
Tj303's Avatar
Australia
14
Drives: 135i Coupe
this also worried me before i took delivery of my 1er.
I prefer the reverse to be at the other end of the stick i.e. after 6th but u do get used to it although still not 100% for me... The thought does cross my mind every now and then to check if i'm actually in first rather than reverse which is a bit annoying
i've never put the car into reverse by accident, but when i got the car for a couple of occassions i couldn't find the reverse gear so put it into 1st by accident. This is likely to present the same problem for anyone not used to it
      04-18-2009, 10:29 AM   #13
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
Personally, I find the BMW practice of slotting reverse beside 1st to be both easier and safer. IIRC, the old 3 speed transmissions always had reverse beside 1st - whether floor or column mounted.
Those who are worried about finding reverse should probably order ther cars with PDC and iDrive. They will then get both an audio and visual warning that they are about to proceed backwards.
Tom
      04-18-2009, 11:00 AM   #14
emm3tt
Out Driving
emm3tt's Avatar
29
Drives:
What, is it a dogleg shift pattern or did you have a 5-speed?
Emmett
01 E46 M3
      04-18-2009, 12:57 PM   #15
radiantm3
Apex Everything!
radiantm3's Avatar
Drives: 2007 Honda S2000, 2017 GT350
2011 E92 M3  [9.35]
2014 BMW i3  [10.00]
My old "rice burner's" reverse was in the upper left as well.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com
      04-25-2009, 11:23 AM   #16
turner23
Drives:
All German cars (VW, Audi, BMW) have reverse adjacent to 1st gear, most Japanese cars put it underneath 5th. I've always had reverse 'top-left', and prefer it there as it's almost impossible to 'accidentally' select reverse.
You gotta want it.
1addicts
