11-19-2008, 07:10 AM | #1 |
Rep 1,660
TPMS is rather useless
TPMS only measures the difference in PSI between the tires. If all tires are at say 30 PSI then TPMS thinks everything is OK.
What is needed is the ability to set a value, say 36 PSI and have TPMS tell you when any of the tires is more than 2 PSI low. (Alarm at <= 34 PSI) |
11-19-2008, 09:29 AM | #3 |
or Rosencrantz
11
Rep 455
Drives: 2008 Montego Blue 128i
When it got cold all 4 of my tires lost the same amount of pressure and the TPMS went off. The old system used relative rolling resistance to guess a flat. but the TPMS is activly measuring the pressure of each tire. iDrive won't let you see it. but that's a software application problem. We can't all have Multifunction displays designed by Poliphony Digital. But I know you could get a lot more out of the iDrive then they let you.
You do however kinda get to set the TPMS. Put the tires at the pressure you want, then reset the TPMS. When any of them gets I think 4 PSI low it goes off. |
11-21-2008, 12:34 PM | #4 | |
Rep 230
11-21-2008, 12:49 PM | #5 |
Rep 812
It's designed to spot a puncture, not stand in for essential regular checks and maintanance....
2019+ BSM M2C 2011-2012: VO 1M Coupe, many toys, Evolve Stage 3. 2008-2011: 135i M Sport Le Mans Blue / Lemon / HGSL. Evolve OBD remap - 390bhp. Also in the family: X3 M40d / Audi S4 (V8)
11-21-2008, 12:50 PM | #6 |
Quality is everything
12
Rep 756
11-22-2008, 07:50 AM | #7 |
Rep 172
I would think that the system reset would store the current pressure that each tire is at as the basis to compare against. If the dealer only filled them to 32 and reset the system, the alarm would then only come on at around 28 psi. If the basis pressure setpoint of the system was fixed at 36 psi there would be no need to reset at all.
