08-08-2008, 06:13 PM | #1 |
Rep 78
How to: USB to read Large drives
I recently bought a Maxtor Basics Portable Storage USB drive. Plug it into the car and no workie. Slap it on my laptop and realize its NTFS. Car doesnt seem to be able to read NTFS. So I set about figuring out a way to convert all 320gigs to Fat32. Only problem is XP wont let you format anything over 32gigs to Fat32. So here is what I did to get it to work:
First I deleted the 300gig NTFS partition using SwissKnife V3 (freeware). Then I created a 32gig Fat32 partition using the same program. From there I used Easeus Partition Manager Personal 1.6.4 (freeware) and expanded the 32 gig partition to 300gig. Note: you lose some space with larger drives. just the way it is unfortunately. Proceeded to load my 8+gigs of music and the car recognized it. I then proceeded to rock out:headbang: Just typed up this little process in case you run into a similar issue. |
08-09-2008, 05:12 PM | #2 | |
Rep 49
08-12-2008, 06:17 PM | #4 | ||
Rep 78
true. but seeing as how systems are coming without floppy drives nowadays this is an easy way to do it inside of windows.:biggrin: no floppy needed. just an internet connection. Quote:
as far as indexing. nope same speed as my USB drive. i have around 9 gigs on it right now. ill update once i fill up more space to let everyone know if indexing speed decreases with the amount of space being used. my bet is yes it will. |
08-12-2008, 06:23 PM | #5 |
Rep 994
Drives: M2, 135i, Xclass
Did the drive work straight off the usb port or did you need an external power supply?
12-20-2008, 05:19 PM | #7 |
Alpine Master
111
Rep 1,310
The 125gb on my 160gb iPod takes 4-ever to index. Like, literally an hour or longer.
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727 |
12-20-2008, 05:45 PM | #8 |
Rep 3,350
I am going to mount this storage array in the trunk, I will have 14 Terabytes of storage, in a RAID 5 array. I am going to use an IBM Fiber Channel to USB converter, and power it with an inverter connected directly to the battery. That is what I am going to do.
12-20-2008, 09:17 PM | #9 |
183
Rep 2,391
HA! you sure that'll be enough for all your music?
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust kw v2 | hotchkis front sway | vmr v710 |
12-20-2008, 10:23 PM | #10 |
Ronnie
15
Rep 556
Thanks for that, I'll try and get around to adding this to the FAQ at some stage. As a follow up question, are you using the USB port to power the drive, or an additional external power supply?
"Lucy" 128i / Sedona Red / Coral Red / Premium Package / Premium Sound |
