07-01-2008, 02:19 PM | #1 |
I no longer work for United BMW!
308
Rep 3,330
Drives: E46 M3, E46 330i ZHP, E36 325i
United BMW - The Wait Is Over! Performance Suspension
The long awaited BMW Performance suspension is finishing it's final details! I have been in contact with BMW almost DAILY on this subject, and I finally am able to offer you the kit!!!! Yes, the springs are Yellow :wink: as portrayed in the catalogs.
I am currently waiting on the kits to come in, however BMW has changed it up a little. There is no longer one part number for both the sport and non sport-package cars. There are now two different kits depending on what options you have on your car. **VERY IMPORTANT** -- WHEN ORDERING, PROVIDE THE LAST 7 DIGITS OF YOUR VIN (VEHICLE IDENTIFICATION NUMBER) IN THE ORDER COMMENTS! *** Springs are sold separately Kit includes: - Rear Sway Bar(Not required for Parts Kit # 33 50 0 444 831) - Front Sway Bar - Front McPherson Struts (2) - Rear Shock Absorbers (2) - Bottom Spring Supports (4) - Top Spring Supports (4) - Front Stabiliser arm rubber bearing (2) - Rear Stabiliser arm rubber bearing (not required for kit # 33 50 0 444 831) - Rear auxiliary shock absorber (2) - Front auxiliary shock absorber (2) - Supporting bearings lower section - All fastening pieces Parts needed to order separately - Front Sport Springs (2) - Rear Sport Springs (2) Feed back can be seen at the following links: http://www.1addicts.com/forums/showthread.php?t=19119 http://www.1addicts.com/forums/showthread.php?t=20219 http://www.1addicts.com/forums/showthread.php?t=17695
BMW CCA, PCA, & CHIN Motorsports Instructor.
07-01-2008, 02:44 PM | #2 |
Rep 1,680
ordered. email with VIN sent. keep us posted on the springs. thnx dan.
edit: dan please don't mail mine. i want you guys to do the install. thnx.
e90 M3, Space Gray / Extended Black, ZCP, ZCV, ZP2, DCT
sold: 2008 BS 135i 6MT |
07-01-2008, 04:49 PM | #4 |
308
Rep 3,330
When you order the kit, I'll add the springs in there when you provide your VIN #.
I just updated the spring prices (found out the price just now). You will need to order 2 front, and 2 rear springs along with the kit itself
07-01-2008, 08:54 PM | #8 | |
Rep 340
No offense Dan, your prices rock.
2008 135i Premium/Sport/Cold CA/HiFi
07-02-2008, 10:38 AM | #10 | ||||
308
Rep 3,330
The entire suspension has to be taken apart, so it is definitely a time-consuming job. Quote:
07-05-2008, 03:01 AM | #14 |
Rep 404
Drives: 16' X5 M-Sport / Space Gray
so what BMW considers a suspension performance upgrade is just shorter springs?
not shock/spring combo upgrade? no coilover? Why would one go this route rather than something aftermarket like H&R? I'm new to all this. |
07-05-2008, 08:45 AM | #15 |
Rep 773
How do you figure ? his initial post lists parts included in the kit and it sounds pretty comprehensive to me. It actually sounds like its everything BUT the springs.
Jeff |
07-05-2008, 10:39 AM | #16 |
Rep 1,680
i think the person was lazy and didn't actually read the thread.
07-05-2008, 08:37 PM | #18 |
Rep 275
i'm not sure why so long if you are replacing the springs and struts? if you already have your NEW setup put together, whats taking the old setup out as one and putting new back in as one? If there are any pieces you need in the old suspension, just buy new ones (bushings, washers, etc).
07-05-2008, 09:21 PM | #19 |
308
Rep 3,330
The kit is the same as the E46 and E90.. which replaces a lot components of the stock suspension. Just doing Springs on a normal car will take some time ( can be up to a few hours), but the kit involves replacing the stock pieces of the suspension.
07-05-2008, 09:53 PM | #20 |
Rep 1,168
07-06-2008, 06:28 PM | #22 |
Rep 2,013
