06-12-2008, 08:27 AM | #1 |
Rep 340
Fuel Consumption: Explanation Please
This refers to the "instantaneous" fuel consumption read out on instrument panel.
SCENARIO: Cruising along (easiest downhill), take note of consumption. Take foot off the accelerator, and consumption drops to 0.0 L/100k relatively quickly (pretty cool). RPM's above idle. Without doing anything else, depress the clutch, & consumption GOES UP (to 3-4 L/100km). RPM's drop to idle. I am sure there is some wonderful technical explanation for this, but I simplistically assume that higher RPM's translate to higher fuel consumption Could anyone enlighten me?
Delivered! 1700hrs Tues May 20 2008: Sparkling Graphite, 6MT, Black Boston Leather, Accented Aluminium, Sun Roof, Pro Nav, Comfort Access.
06-12-2008, 08:34 AM | #2 |
Alpine Master
111
Rep 1,310
When the engine is breaking the car (coasting in gear), the injectors are not providing any fuel. Depress the clutch and the engine drops to idle, using the idle level of fuel. You can be going fast enough that even though you've depressed the clutch, you're still going to get seeminly infinite efficiency but thats because your speed/consumption is more than 99.9mpg (or whatever the L/100km equivalent is.
The car manual says that when coasting in gear, the car doesn't use any fuel.
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727 |
06-12-2008, 09:26 AM | #3 | |
Rep 340
Doesn't the motion of the pistons cause the air to expand / contract with change in volume? Would the pressure changes be an issue? (Probably not?). Do the valves (inlet/outlet) stop opening? I think I have trouble conceptualising the cylinders being "empty" (ie just air), but I am sure I am being, as I said, a bit dumb.
06-12-2008, 09:38 AM | #4 |
Rep 841
Everything still happens the same: cylinders go up and down, valves open and close. Just no fuel is delivered and no spark is ignited.
Yes, air is still compressed in the cylinder, and it is this effect that provides the engine braking force. The engine is able to keep turning due to the momentum of the car. Once you press the clutch pedal, you decouple the car's momentum from the engine, and thus the DME has to keep the engine turning by introducing fuel and driving the engine at idle speed. |
06-12-2008, 09:48 AM | #5 |
Ronnie
15
Rep 556
As an aside to this, my brother-in-law who is a mechanic, and has designed some of his own engines, suggests that during the 4 strokes when engine braking, there is both compression of air on the compression stroke, but also vacuum during the explosion downward stroke.
During early breaking before the rings have sealed well, engine breaking can draw oil up the side of the cylinders which can be bad for the engine. He strongly recommends avoiding engine breaking during break-in.
"Lucy" 128i / Sedona Red / Coral Red / Premium Package / Premium Sound |
06-12-2008, 09:57 AM | #6 | |
Rep 841
06-12-2008, 10:13 AM | #7 |
Rep 329
yup, cylinder back pressure is a good thing, it forces the rings to expand outward which in turn evenly seats them to the cylinder walls.
