06-07-2024, 07:21 AM | #1 |
Rep 14
G30 rattle from the dash
Hello,
I have a '23 G30 LCI with 35k km and there is something behind the instrument cluster that rattles whenever I go over road imperfections, but only in warmer days (15+ degrees C). Sounds like plastic on plastic or plastic on metal, maybe a frame or wire. It's not the sunroof since I can clearly hear it coming from behind the instrument cluster. Anybody ever encountered it? https://www.youtube.com/shorts/IlnrA6BjEdI https://www.youtube.com/shorts/2NJc7T2tRLc |
06-07-2024, 05:47 PM | #2 |
Rep 351
I had exactly the same noise and it was driving me nuts. I got into the dash from underneath and via the left side after removing the side cover. Must have very thin arms to wiggle into there. Nothing helped. As you, I was certain it wasn’t the sunroof. I was wrong. I decided to lube the gaskets just in case. That wasn’t it either. While I was up there I just happened to press my hand down against a plastic area near the front left-side of the roof. That was it! I recommend you do consider the roof even though you’re convinced it couldn’t be the cause.
