Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      03-09-2024, 12:59 AM   #1
AlpineF82brrr
Drives: 2015 BMW M4
Unhappy HELP! My S55 has a rough start and rough idle but drives fine.
Hello,
I’m writing here that in some off chance someone might have experienced something similar and has some useful feedback. I’ve seen a few posts about rough idle but none of them have helped me in my case so far.
The car turns on and starts at rpm 1.2k or so then will dip to like 500 rpm’s, back to 1.3k to 700 to 1.2k and just misfire through the whole cat heating sequence. The rpm’s are always random and sometimes it doesn’t do it as bad. It chops like a cammed vett, and revs itself up sometimes during cold start.
The car drives fine but in idle it def misfires a bit and on cold start it’s the worst.
The only codes I got were all cylinders misfiring and just some codes saying all the cylinders : Combustion misfires, cylinder : harmful to exhaust gases after starting. Other than it telling me all cylinders are misfiring it doesn’t tell me what’s causing it. And again it only misfires on idle the car drives completely fine.
The car was stage 2, front mount intakes, downpipes, charges pipes, J pipe, mid pipe, stock muffler, crank hub is done, and it used to run CJ E85 tune. This issue persists both in stock and stage 2 tune.
Things that my mechanic has tried are
New set of sparks (old owner had 5 NGK and a Bosch????)
Not new injectors but injectors that were fine on another car put in
Removing front mount intakes and replacing them with stock intakes
Cleaning the MAF sensors
Things that he’s planning to do
Replacing downpipes with stock cats
Checking O2 sensors
But that’s where we’re at.
      03-09-2024, 08:48 AM   #2
wheela
wheela's Avatar
Drives: 2015 BMW X1 35i M-sport
Do you have any logs of this happening? Also you mentioned you have new (used) injectors, were they coded on installation, and are you certain they are the correct injector?
      03-09-2024, 01:55 PM   #3
AlpineF82brrr
Drives: 2015 BMW M4
I think they’re OEM injectors off his own M3 that he totaled, he didn’t code them just put them in. He’s also getting my own injectors cleaned to put those back. As for logs I’m not sure how to do that. Do I just start logging on BM3 and start the car and also log me driving?
      03-09-2024, 02:21 PM   #4
wheela
wheela's Avatar
Okay, the injectors definately need to be coded, as they all flow slightly differently, and the DME needs each injectors specific flow value to control them properly. Can't say for sure that's the only thing going on, but I'd start there before doing anything else.
      03-09-2024, 06:37 PM   #5
AlpineF82brrr
Drives: 2015 BMW M4
After doing some research I’ve heard a lot of people say different things but majority says you don’t need to code s55 injectors.
      03-09-2024, 08:17 PM   #6
wheela
wheela's Avatar
Well, I just researched a bit and you seem to be right. Older eu5 cars need coding, but apparently newer eu6 cars just need small mixture adaptation reset:
https://f80.bimmerpost.com/forums/sh....php?t=1534478
https://f80.bimmerpost.com/forums/sh....php?t=1795072
      03-26-2024, 02:39 PM   #7
Wan15bad
Drives: 2008 E90 320ci sport
Originally Posted by AlpineF82brrr View Post
Hello,
Checking O2 sensors
Seem to have same issue here, did this get resolved for you?
Many thanks
      03-31-2024, 11:34 AM   #8
summernightruns
summernightruns's Avatar
Drives: F80
I would check the PCV plastic hose that attaches the valve cover to the front turbo inlet. They can be brittle and break
      04-12-2024, 12:26 AM   #9
AlpineF82brrr
Drives: 2015 BMW M4
Bumping this post because I have an update
I haven’t checked the PCV as the above comment says yet
But
I had brand new injectors put in
Brand new coil packs
Brand new sparks again
Brand new MAF sensors
The issue gets a little better on startup after cleaning the MAF sensors then it deteriorates progressively and starts revving itself randomly and chopping a little bit.
After it started getting worse again(it had been good on startup suuper smooth the RPMS didn’t bump up and down at all then it got worse again after about 20 days)
I replaced the MAF sensors this time which made it better again just not totally smooth like last time. I wonder what could be causing this issue?
Shops aren’t sure either but has anyone ran into this issue before?
      05-08-2024, 08:14 AM   #10
Alpine-F80
Alpine-F80's Avatar
Drives: 2017 M3
But
Did you ever solve your issue? I would not think MAF in your case, would guess something related to the plugs/coils/injectors.
      05-09-2024, 05:01 PM   #11
gcant35
gcant35's Avatar
24
Drives: 2015 BMW M4
I had the same issues, bascially same mods as you. I had multiple "lean air" codes, the car would rev and shake side to side like a tractor starting up, sometimes killing out completely- I'm tuned with BM3 Stage 2 and have read multiple forums stating that turning cold start off or having "GTS roar" enabled could produce the rough idle and it was "normal" if you're tuned with intakes...
Tried fixing that, resetting adapations, etc. I ruled out spark plugs as they're brand new and gapped to spec- At that point I just assumed I had a massive air leak, however smoke test revealed no leaks. My mechanic is an extremely experienced BMW master tech, he ruled out injectors or anything like that. I had engine light on from 02 sensors (coded off- catless DPs) however they wouldn't cause this issue. In layman's terms- the front mount intake design is trash- placing the MAF sensors in a position that the car frankly doesn't like.
Long story short, he was right. The front mount intakes were the issue for me, which sucks because they looked pretty cool. Not sure if this is ALL front mounts or just the set I purchased, but I removed them and went back to standard, gave MAFs a good cleaning and car now runs super smooth on startup with no codes
      05-23-2024, 04:23 PM   #12
NORAGRETS
NORAGRETS's Avatar
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
Hello,
Checking O2 sensors
What intake are you running?
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021
      05-23-2024, 04:24 PM   #13
NORAGRETS
NORAGRETS's Avatar
But
My suspicion is your intake, is it aftermarket?
      05-24-2024, 03:41 AM   #14
djpeetur
djpeetur's Avatar
Drives: F80
Go stock KN filter, plugs, coils, and eu5 injector if tuned. Those 4 things changed my car life. No more hesitation or misfire. Straight smooth gas guzzler.
f80post
