      02-08-2008, 02:25 PM   #1
Matt60158
///M
13
Drives:
Battery Mount in Trunk
After having learned that the battery will be mounted in the trunk in another thread I wanted to see if anyone had a picture of the mounting location-compartment?
I am hoping a lightweight(16lb) drycell from oddessy will fit in to quickly drop 20lb+. I have been using one on my mazda6 for 2+ years and it has started fine in teen temperatures. Just need to be sure to drive it atleast once a week or use battery tender to keep it from being run down.
http://www.odysseybatteries.com/battery/pc680series.htm
680 Cranking Amps
220 CCA (worked fined for me in teen temperatures)
      02-08-2008, 02:28 PM   #2
ChrisK
ChrisK's Avatar
Drives: '19 M2C
The frickin battery in this car is HUGE! It looked like a Truck battery.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      02-08-2008, 02:41 PM   #3
Twisted
TwistedHouse
Drives:
Is this what you're looking for?
Courtesy Of Motor Authority.
      02-08-2008, 02:49 PM   #4
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
Here's a pic of the battery in the trunk - Chris' description is correct!!! And remember kids, there is no such animal as a 'maintenance-free' battery, take it from someone that still has a can of 'NO-OX-ID "A"' dielectric grease (conductive cosmoline to be more exact ; -).
      02-08-2008, 02:50 PM   #5
Matt60158
///M
13
Drives:
Thanks this is exactly what I wanted. Hard to see depth from this angle but it looks huge. Should be able to put an odessy in there pretty easily maybe even laying flat for a lower center of gravity.
Rought estimate stock battery is 40 lbs.
40lb-16lb = 24-25 pounds lost and lower C.G.
      02-19-2008, 10:03 PM   #6
djmBMW
djmBMW's Avatar
Drives: 135
I hope the battery is Huge...last one I had in a trunk was in a Alfa...very slow crank'n in the winter!
      02-23-2008, 08:12 PM   #7
TwinturboBMW07
Drives:
dang thats going to make hooking up aftermarket subs alot easier
1addicts
