12-30-2007, 10:46 AM | #1 |
Rep 518
BMW's New V-8 Twin Turbo
The new V8 engine with Twin Turbo technology and direct gasoline injection, is likewise making its world debut in the BMW X6. Displacing 4.4 liters, this eight-cylinder with maximum engine output of 400 hp and peak torque of 450 lb-ft available over an unusually large range of engine speed from 1,800–4,500 rpm, is the most powerful engine ever seen in a BMW X Model.
The new eight-cylinder is indeed truly impressive not only through its outstanding thrust and pulling force, but also through its compact dimensions. For this is the first eight-cylinder gasoline engine in the world to feature its turbocharger in the V-section between the two rows of cylinders. |
12-30-2007, 11:01 AM | #2 |
Rep 10,176
That's a work of art. Unlike the 135i's turbos, those look like an easy swap.... top and center. This engine might be capable of unbelievable amounts of output with tuning. :wink:
12-30-2007, 11:02 AM | #3 |
Rep 1,938
Sort of like a Duramax diesel or Ford Powerstroke with the turbo(s) in the middle. Very compact design, I wonder which high perfomance model theyll put it in? 5 series? 7?
12-30-2007, 08:32 PM | #5 |
No longer moderate
325
Rep 4,401
I remember the old Ford racing engines with the heads flopped like that to put the exhaust ports on the inside. I think Ferrari used that at some point also. Neat tech.
12-30-2007, 08:47 PM | #6 | |
Acquiring the taste.
Rep 151
I really hope this engine gets into more cars than the X6. Even though I'm in the small minority that likes the X6 design, I highly doubt I'd ever buy one. |
12-30-2007, 09:05 PM | #7 |
NRA Life Member, BMW CCA 30 year member
181
Rep 2,614
What a neat-looking...thing! Beautiful mechanism.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason |
01-08-2008, 10:42 AM | #11 | |
Rep 213
01-08-2008, 02:29 PM | #14 |
Rep 98
The 4.4L TT doesnt appear to use an air-air FMIC but rather two liquid-air SMICs. You can see the coolant line ports closed up. liquid-air ICs can cooler air much better, but once they get heat soaked they take much longer to cool down. I am a little suprised by the move actually but then again I was surpised by the 4.4L turbo itself and the turbos mounted in the V as well.
01-08-2008, 03:38 PM | #15 |
Rep 361
noob question/thread hijack
how does a turbo make you go faster? looks like a fan :iono:
:roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel: :roundel:
01-08-2008, 03:52 PM | #16 | |
Rep 98
01-08-2008, 04:33 PM | #17 | |
Rep 119
01-08-2008, 04:59 PM | #18 |
Rep 98
01-08-2008, 05:01 PM | #19 |
Santa Fe Concorso
103
Rep 2,984
Oh, man, the "bundle of snakes" header system on that baby was awesome!
01-08-2008, 05:09 PM | #21 |
No longer moderate
325
Rep 4,401
You could get a split crank V8 to act like a single plane crank when you used what was known as a '180 degree' header system.
01-08-2008, 05:26 PM | #22 | |
Rep 312
