BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
Mporium BMW
      06-29-2023, 12:04 PM   #1
034Motorsport
034Motorsport's Avatar
Drives: 2018 BMW 340i
Dynamic+ Sway Bar Kits for BMW E9X Now Available from 034Motorsport!
The 034Motorsport Dynamic+ Sway Bar Kit is available for BMW E9X Chassis. The 034Motorsport Dynamic+ Sway Bar Kit features perfectly-matched front and rear sway bars made from high-quality spring steel for maximum rigidity and durability.
Designed to reduce body roll, improve turn-in, reduce understeer and enhance steering feel, 034Motorsport's Dynamic+ Sway Bar Kit is the ideal upgrade for those in search of confidence-inspiring handling on the street and track.
Dynamic+ Sway Bars are available individually for those that are looking to upgrade in phases or match an existing customized suspension setup.
TRACK-PROVEN HANDLING PERFORMANCE:
The Dynamic+ Sway Bar Kit was thoroughly evaluated on the street and track before release to ensure they provided the most optimized handling experience possible.
SWAY BAR BENEFITS:
DYNAMIC+ SWAY BAR KIT:
The Dynamic+ Sway Bar Kit features perfectly-matched front and rear sway bars made from high-quality spring steel for maximum rigidity and durability. This kit contains perfectly-matched front and rear sway bars designed to reduce body roll, improve turn-in, reduce oversteer and enhance steering feel. 034Motorsport's Dynamic+ Sway Bar Kit is the ideal upgrade for those in search of confidence-inspiring handling on the street and track. By installing the Upgraded Front and Rear Sway Bars together, E9X BMWs will have the best balance of adjustability to dial in desired rotation and stiffness.
FRONT SWAY BAR:
The front sway bar upgrade on the E9X BMW will dramatically improve the steering directness and reduce body roll. With three points of adjustment, dialing in your handling has never been easier. When installing the 034Motorsport Front Sway Bar with the Factory Rear Sway Bar, the increased stiffness in the front suspension will create more understeer and reduce oversteer tendencies in E9X BMWs, making the car more predictable and safe at the limit.
REAR SWAY BAR:
The rear sway bar upgrade on the E9X BMW is designed to reduce body roll & understeer, while improving turn-in, rotation, and oversteer during cornering. Installing the 034Motorsport Rear Sway Bar with the Factory Front Sway Bar will provide the driver with an oversteer bias setup and would be great for those looking to have more rear-end rotation and “loose” handling!
FITMENT NOTICE:
034Motorsport Dynamic+ Sway Bars are available in both M and Non-M Front Suspension Configurations. Some aftermarket coilover kits for Non-M E9X vehicles reposition the end link pick-up point to the same location as the M3, so please choose appropriately.
SWAY BAR FEATURES:
FRONT SWAY BAR:
  • 2-Way Adjustable
  • Soft: 52% Increased Sway Bar Rate Over non-M
  • 36% Increased Sway Bar Rate Over M3
  • Stiff: 78% Increased Sway Bar Rate Over non-M
  • 59% Increased Sway Bar Rate Over M3
  • 30mm Diameter
  • Hollow Design with Thicker Walls Compared to Factory Bar
  • Black Powder Coating for Durability and Stealthy Appearance
  • Reduces Front Body Roll
  • Increases Front-End Agility
  • Improves Steering Directness
034MOTORSPORT MOTORSPORT FRONT END LINKS:
  • OEM+ Quality with Adjustability
  • Quieter with Less Maintenance than Spherical Motorsport End Links
  • +/- 0.75" of Adjustability (1.5" Total Adjustment Range)
  • Adjust Sway Bar Preload - Essential When Corner Balancing Lowered Vehicles
  • Increased Strength for Stiffer Sway Bars, Heavier Loads and Aggressive Use
  • Improved Sway Bar Reaction Time & Accuracy
REAR SWAY BAR:
  • 2-Way Adjustable
  • Soft: 21% Increased Sway Bar Rate Over M3
  • Stiff: 35% Increased Sway Bar Rate Over M3
  • 22mm Diameter
  • One-Piece Design with Solid Spring Steel Construction
  • Reduces Rear Body Roll
  • Reduces Understeer
  • Improves Turn-In Rotation when Cornering
Check It Out Here!
034Motorsport - Engineering and Manufacturing Performance Hardware & Software Upgrades for Audi, Volkswagen, & BMW Enthusiasts Since 2005.
YouTube // Instagram // Facebook
      06-29-2023, 03:23 PM   #2
amg6975
amg6975's Avatar
503
Drives: '12 M1.5, '05 ZHP, '98 M3/4/5
Does the kit have perfectly-matched front and rear sway bars?
      06-30-2023, 05:18 PM   #3
034Motorsport
They're perfectly matched in terms of overall handling performance and balance!
-Justin@034
m3post
