      03-22-2023, 04:18 AM   #1
ELF
Drives: BMW 125i
e82 N52 RHD Exhaust Manifold removal
Hi Guys,
I am halfway through replacing exhaust manifold gaskets on stock exhaust manifolds for my e82 125i N52 engine, manual right hand drive car.
I was able to remove the rear manifold ok, but the front manifold does not want to slide out, hits on bell-housing, engine mount bracket and I think steering column (right hand drive you see). What do other people do? Do I need to jack the engine up and remove the RHS engine bracket to tilt engine?, Support engine from the top and lower the Subframe with everything connected just enough, can i just remove the steering rack and let it hang - does that give me just enough space? Or try and replace gaskets without removing the manifold from its little prison?
Any tips??
Cheers friends.
EDIT: you totally just have to release the in-car steering column adjuster lever, so the steering wheel flops about, then remove the two bolts that hold the steering column onto the sub-frame. Then you can slide the rack out and and around a bit to give enough clearance to slide the exhaust manifolds out around the engine mount. - happy dayz
1addicts
