Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Health, Fitness, Martial Arts, and Nutrition
      08-20-2022, 06:41 AM   #1
Llarry
Llarry's Avatar
24015
Drives: 2025 M850i GCpe
Acupuncture for hip pain
I'm older and have developed bursitis (inflammation of the bursa in my hips.) Steroid injections in the hips have only provided temp relief but I am scheduled to get ultrasound-guided inections in ten days or so -- the more accurate placement of the steroid should provide longer-lasting relief. I'm also doing physical therapy, which is strengthening my legs and hips and helping gradually reduce the pain level. Progress is slow but sure.
Two days ago I had an initial appointment with an acupuncture clinic in town. The doc has studied in China and has 20 years of experience, so seems well-qualified.
Anyway, the first session (of scheduled weekly ten) was interesting. I'd not had acupuncture before. The needles are ultra fine (think diameter of a hair) and do not hurt. The routine is for the doc to place the needles (in my case, in my hips and back) and then leave me alone for 20 minutes, then return and remove the needles. No immediate relief noted, though the doc says this should help with the ongoing physical therapy. I'm hopeful I will see relief over the medium/long term.
Unfortunately, not covered by insurance (Medicare) in my case.
'25 M850ix GC
BMW CCA 31 years
      02-09-2025, 07:37 AM   #2
Llarry
Llarry's Avatar
24015
Revisiting this topic for the benefit of any readers, I think I have to admit that acupuncture did not provide much relief. It's been several years, but I think I ended up spending the better part of a thousand dollars without much result.
I suspect acupuncture can work well for some scenarios, but it did not work particularly well for me to reduce hip pain.
'25 M850ix GC
BMW CCA 31 years
vreihen1623698.50
chassis8592.00
      02-09-2025, 08:04 AM   #3
MaxVO2416.00
      02-09-2025, 12:35 PM   #4
chassis
chassis's Avatar
8592
Drives: 9Y0 Cayenne S
What are your exercise regimen and weight (BMI) status?
MaxVO2416.00
      02-09-2025, 02:11 PM   #5
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
Been having same issues as you mentioned. I took a look at my shoes and tried that method. My left leg is 3/8" longer thn my right so that causes unique gait plus I L4/L5 disc issues. Things as a 20 yr old you'd never think they would bother you. Till that age....mine was 56 and then things have been a bit slower or a bit planned out.
I have gotten my bmi lower but not gained back muscle yet that is difficult. Better shoes have kept me more in line than be jabbed or prodded by a Dr. Now to just get shoulder surgery or not. I'd rather not be out of work for 6-10 months.
chassis8592.00
      02-09-2025, 02:30 PM   #6
MaxVO2
MaxVO2's Avatar
416
Drives: BMW M8 Coupe
****THIS.
chassis8592.00
      02-09-2025, 02:41 PM   #7
MaxVO2
MaxVO2's Avatar
416
***The bursitis and other such issues can happen for a variety of reasons.
Often, excess weight is a factor, but also lumbo pelvic hip issues related to a lack of tonicity and loss of function/strength in several important muscles like the glutes (esp the glute medius and minimus) as well as the deep six pelvic muscles (obturators, and gemellus muscles, quadratus femoris, etc..)
Functional or anatomical leg length issues can also be related or causative, along with degenerative changes in the hip due to FAI (Femoral acetabular impingement syndrome - of which there are three main types..)
Issues related to poor balance, and motor control of the hips all the way down to issues in the feet (final link in kinetic chain) can greatly affect the health and longevity of the hips, the knees, the back, etc...
Postural issues, etc... LOTS of things can cause or exacerbate a hip bursitis issue and a decent orthopedist, movement person can do the appropriate scans and rule out or confirm arthritis or degenerative changes and then do the correct testing for range of motion, strength, alignment and proper neuro muscular movement patterns.
Anyway, it is complicated and acupuncture or other similar modalities often do not address the root cause of the problem and only treat the symptoms.
But yea, excessive BMI (greater than 25) and exercise habits plus postural issues are often causative or contributive to the issues the original poster indicated they have.
chassis8592.00
      02-09-2025, 02:45 PM   #8
MaxVO2
MaxVO2's Avatar
416
****Yes, it is like the alignment in a car - if it is off, it will contribute to greater wear and tear on tires and potentially other components.
A leg length discrepancy will affect the entire kinetic chain. Orthotics, and some flexibility and proper strength work can somewhat address other issues related to the altered locomotor gait issue and its affect on other structures.
Some people with significant leg length discrepancies compensate more significantly for it than others but the bottom line is unequal leg lengths is less than optimal, and can greatly increase wear and tear on other structures.
chassis8592.00
      02-09-2025, 03:53 PM   #9
chassis
chassis's Avatar
8592
I have had a couple of minor orthopedic complaints (knee, shoulder, lumbar, hips) over the years. Over the past 12 months I have lost a little weight (didn't have much to lose in the first place) and have added strenuous cycling in the summer and swimming in the winter.
Swimming in particular has helped all of the complaints the most. Kicking and pushing off the wall (knees and hips) and front crawl/freestyle (lumbar, shoulders) have helped alot. I am more limber and ache-free than I have been in 15 years.
And the cardio benefit from cycling and swimming has more than replaced the benefit I enjoyed from running. I stopped running a few years ago because of undiagnosed mild-moderate hip bursitis that wouldn't heal and wasn't helped by rest or changes in technique/form.
      02-11-2025, 05:58 PM   #10
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
From my experience with injuries, going to a good orthopedic who can provide specific stretches is almost always the answer.
Secondly, to keep things in order after the pain subsides - Kettlebell swings, traditional 2 arm and 1 arm I find are fantastic for evening out the 2 sides of the body. Possibly yoga, definitely swimming, and for sure buy a good tens unit, because they feel amazing and can help alot.
Stage 2 BM3
Originally Posted by GrussGott View Post
Sounds pizzagatey.
      02-14-2025, 06:50 PM   #11
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
I'll just speak to why I feel acupuncture can work for some things and not others.
I look at it just like aerating your lawn. The needles are creating a pathways for blood (and the nutrients it carries) to get through muscle fibers that have become so tight/dense/malnourished blood can't get to them. It's not going to fix any bone or joint issues. But things like tight muscles or muscles that are pulling you out of alignment it may help with. If that's correct or not I don't know. But it's what makes sense to me.
I had it done to my shoulder years ago. Had a knot around my shoulder blade that I just couldn't stretch out on my own. Few trips and being a pincushion later and it's been fine ever since. For my situation it's worked. I only had to pay and extra $5 to have the chiropractor stick me. So wasn't really out anything trying it.
I think for the most part massage is similar to acupuncture in that it's allowing blood to get in and heal to places it couldn't. Muscle fibers need to be loosened to allow healing.
      02-15-2025, 12:02 PM   #12
eleven11
eleven11's Avatar
442
Drives: -F31-
Acupuncture can help in some cases, but isn't a panacea.
Trochanteric bursitis can be stubborn, and often stems from chronic asymmetry somewhere (spine, hip, legs). This is, of course, interlinked to areas of weakness and tightness; and, compounded with a higher BMI.
Though it might not alter your treatment plan, MRI might reveal problems (e.g. tears) of the gluteal muscles and surrounding soft tissues.
Your foundation is to work closely with PT. It sounds like that was pursued. Consider a "second opinion" with another PT - you might have better results. You have to put in the effort at home regularly. I like the Myrtl Routine and monster walks at home.
Though the evidence isn't a amazing, consider PRP injections and shock wave (ESWT) therapy. Also, dry needling (with your PT) as an alternative to acupuncture.
Topical diclofenac (Voltaren gel, OTC) or a prescription compounding cream can be very helpful for symptom relief.
Finally, I'll assume your physician has diagnosed this correctly. However, this condition can often be a secondary phenomenon of the hip joint itself or lumbar spine. If the former, a simple fluoroscopically or ultrasound guided corticosteroid injection into the hip joint (not the more superficial bursa) might be what you need.
chassis8592.00
Llarry24015.00
