| 07-23-2022, 07:45 AM | #1 |
Rep 9
E61 Automatic Luggage Roller Cover coding
Hi fellas,
ISSUE: I have an issue in my E61 Touring 2010 with luggage compartment roller cover. After few years of driving this car I realized that as I open the automatic (hydraulic) tailgate, the cover pops-up to the top position, BUT after closing the tailgate it should be dragged to the lower closed position automatically (all the time I did it by hand), but it doesn't. It stays at the top. RESEARCH: after looking on the internet for solution I found confusing information about how it should properly work. One say it should pop-up (spring like) to the top when you open the tailgate, and dragged back down automatically by the motor when you press close button. Like so: Others say that it should automatically dragged up AND down. Like so: The reasons of malfunction may differ, mechanical, electrical and coding (cover is controlled by Temic LCPA module). Mechanical and electrical (wiring, moisture) factors I already checked and even changed the module once, had no difference. I have found the mention from someone that once dealer coded this function off after the oil change. QUESTION: So the question is: does anyone knows and can explain what coding I should check/perform to make the damn cover roll back to its place automatically after closing the tailgate? I'm looking for right FDL code. ![]() ![]() ![]() Hope you guys can help me with this one I wasted so much time on this, not so important, issue that it became matter of principle.. you know.. ![]() |
| Bookmarks |
