BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      11-12-2008, 09:13 AM   #1
rawedge2
rawedge2's Avatar
61
Drives: 05 STI - 08 M3
ACTIVE STEERING.. confusion
THERE IS NO ACTIVE STEERING ON THE M3...
Servotronic "varries the amount of power assist"
and does not change steering ratio...
my question makes sense for someone with active steering..
((at low speeds you have to turn the steering wheel less.. so a tighter turn takes less turn angle..
at high speeds you need to turn the steering wheel more... so a lane change aquires more angle...
--i guess the only way to descibe why is there is less "percent error"?? in your steering at high speeds.. (a slight accidental tug is not going to have as large an effect..)
so now my question.. when its off how is it set..
-1-are the high speed turns the same and low speed now requires more turn angle..
-2-are low speed turning angles the same and now high speed turning is tighter??
... i ask because if -1- is true then it is smart to keep active steering ON because it makes life easier
-if -2- is true then in performance driving i think i would want it OFF as i would rather the tight steering at higher speed... ))
..what a waste of time thinkin about that..
2008 E92 M3 (03-08-2008-first delivery)
JET BLACK on BLACK w/Carbon Leather, 19's, Tech, 6spd..
      11-12-2008, 01:59 PM   #2
Technic
Technic's Avatar
2285
Drives: 2021 i3S, 2024 i4 M50
There is no confusion here, as there is no active steering in the E9x M3.
Originally Posted by rawedge2 View Post
active steering changes the steering ratio according to speed..
Correct me if i am wrong:
Hope i didnt confuse the sh*t outa anyone..!
do i make sense.. (i just cant see having a looser steering at high speeds a positive)
      11-12-2008, 05:53 PM   #3
lucid
lucid's Avatar
Drives: E30 M3; Expedition
+1
But I'm sure after about 5-6 posts on this thread, someone's going show up and ask how the active steering feature works on the M3, or state that he hates the active steering on the M3 because minivans can outsteer him.
      11-12-2008, 07:02 PM   #4
rawedge2
rawedge2's Avatar
61
So servotronic is not active steering..?
      11-12-2008, 07:06 PM   #5
Technic
Technic's Avatar
2285
No, it is Servotronic...
      11-12-2008, 07:56 PM   #6
lucid
lucid's Avatar
It just varries the amount of power assist, not the steering ratio.
      11-12-2008, 08:20 PM   #7
watrob
watrob's Avatar
Australia
140
Drives: MY2022 X5 M-Sport 45e White
Hi have Active Steering on my X5 and you have to remember how it works when you go from one car to another. When you parallel park in a tight space and turn the steering wheel to much you hit the curb with edge of your wheel rim.
My wife is getting good at giving the front wheel a good smack on the curb!
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked.
m3post
