07-05-2021, 04:44 PM | #1 |
Rep 223
Drives: F86 X6M // E53 X5 4.8is
Hi guys, my V8 engine started to burn oil since last service, roughly 2500kms burns 1 litter. I have an appointment coming up tomorrow to do an engine diagnosis, just curious any of you had an engine diagnosis before and what's it looks into?
07-05-2021, 04:47 PM | #2 |
Rep 13
What's the mileage?
Sounds like normal oil consumption to me. |
Lighting.Grey74.00 |
07-05-2021, 04:51 PM | #3 |
Rep 223
07-06-2021, 12:19 AM | #4 |
Rep 223
No one did an engine diagnosis before?
07-06-2021, 10:09 AM | #5 |
Rep 2,517
Are you sure it is burning oil? Not just loose drain plug or something?
07-06-2021, 10:16 AM | #6 |
Rep 223
07-06-2021, 11:44 AM | #7 |
Rep 334
I assume you are talking about your 16 X6M, so S63TU engine. F85/86 forum will be your best bet. I see you've asked.
I doubt your engine has a loose drain plug. I assume you were told by the computer to add 1L, and not that you have been tracking its oil consumption (from a measured fill, then measuring subsequent top ups in relation to the oil sensors readout. That computer rounds to the nearest whole L IIRC. So you won't get add .25L or whatever, just add 1L, as its better to have slightly more than too little (in most cases, YMMV) While there is a class action lawsuit again the N63/S63 engines for excessive oil consumption, 1L/2500KM would worry me personally. Possible you have a bad sensor, or were low a bit, and the computer sent the message. You also mentioned white smoke on hard acceleration on another post. Is this still happening? |
07-06-2021, 12:01 PM | #8 | |
Rep 223
when I dropped off my vehicle this morning, I was told every 1500km/1L is within tolerance, but to me that seems too much. For that white smoke, it happened once on the high way, when I floored the gas pedal(when you can feel the bottom click). And after about five minutes, I tried again but no smoke or just a little bit, not like the first time tons of smoke came out. After that I never pushed the vehicle so didn't happen again. |
07-06-2021, 12:04 PM | #9 | |
Rep 334
White smoke + loss of oil can be a headgasket. Doubtfull given what you have said tho. See what the dealer says. |
07-06-2021, 12:25 PM | #10 | ||
Rep 223
I doubt they are going to find anything, I feel like those diagnosis are BMW BS, that's why I asked if any members done one before, and what's that about. Anyway I hope they find the problem, since I still have warranty till end of this year. |
