      04-15-2020, 11:20 PM   #1
crazyazz
Drives: E46 M3
DP install guide or videos for RHD cars?
Hi guys,
Are there any guides or videos for installing Down pipes on RHD 135i?
Thanks
      06-18-2020, 05:19 PM   #2
YakuzaWAFD
Drives: BMW 135i, Alfa Romeo GT
I tried to install my VRSF the other day but could not find anyway to get to the v band due to the steering column and the engine mount. I have seen that the newer F2x models have a hole through the lower control arm to access. I will have to take it to a shop to get it done now.
      06-22-2020, 06:39 PM   #3
dainese
Drives: BMW 135i
      06-25-2020, 05:35 PM   #4
crazyazz
Drives: E46 M3
I have read that the steering rack is in the way to install on RHD cars.
      06-25-2020, 09:32 PM   #5
totti84
Australia
112
Drives: N54 135i 6MT
If you're located in Sydney and would like them installed PM me
      06-25-2020, 10:03 PM   #6
crazyazz
Drives: E46 M3
Thanks for the reply mate, but located regional VIC.
      06-28-2020, 04:12 AM   #7
Aminal135
Drives: Bmw 135 n55 e82
Hi
Ye I changed mine n55 . It’s possible but bit of a mission . I had remove the the engine mount and have a jack to keep the engine raised . Only then you get access to the Dp
      06-28-2020, 06:48 PM   #8
vtl
vtl's Avatar
Australia
1493
Drives: 2008 BMW 135i MT
Have done many DP installs on N54s, that video is pretty useless since we have the steering rack in the way.
For most people I would recommend unbolting the steering shaft from the rack, supporting the engine from above with an engine support and unbolting the 6 subframe bolts and let the subframe hang from the suspension. This wont take long, and will give you plenty of space to remove and install the DPs from the vbands. Have known plenty of people who spent 12 hours underneath the car trying to get the vbands connected in the tight space. Better off spending the 15 minutes to remove the stuff thats in the way instead of trying to do it all in place.
      06-30-2020, 08:15 AM   #9
Reppunkamui
Drives: BMW 135i
Just did it on my 2010 135i N54 last week.
First/longer DP is a pain, but you can do it without lifting/supporting engine. Second DP is easy after first one is out.
Unlock steering wheel height, unbolt steering rack and push to front of car, remove heat shield near driver front tyre. The heat shield space is basically where you fit your right arm with wrench to do most of the work.
Getting the Vbands off was harder than getting them back on for me...
May not be helpful, but I found it was easiest, to remove stock DPs with top O2 sensors attached (so unplug and take them off clips). But, to install catless DPs without those top O2 sensors and attach them after installing.
      07-05-2020, 09:37 PM   #10
crazyazz
Drives: E46 M3
Thanks a lot mate , that info will help when I get around to installing them
      07-10-2020, 06:48 AM   #11
juld0zer
Australia
480
Drives: Prev 135i 7DCT, Now 130i 6sp
Originally Posted by Aminal135 View Post
Hi
N55 is easy on a 135i. N55 is a pain on an E9x though because the access to the clamp bolt is very difficult. You will need an articulating ratcheting ring spanner as you won't get the angle with a regular one.
1addicts
