XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      06-25-2019, 07:50 AM   #1
Andrea91
Drives: BMW X3 F25 LCI
Steering Wheel compatibility question
Hi,
I want to retrofit multifunction control and also to replace the steering wheel with this one
https://www.ebay.it/itm/293120845256
which should be compatible with my E84, I asket the seller and he told me that is not compatible with my car even though this steering wheel which look the same is compatible
https://www.ebay.it/itm/331696848808
Can you help me with this?
PS: Do you know what else I need to retrofit multifunction control?
      06-25-2019, 03:09 PM   #2
NYBulldog
Specialist
1310
Drives: Nikes
The actual steering wheel will work. If you don't have a similar airbag you need to get one. You can use 3er, 1er, X1 or Z4 steering wheels. However I believe the multifunction control is trickier and requires a few more things. In the US all cars come standard with multifunction so I'm sorry but I couldn't help you with that part of the retrofit.
      06-26-2019, 05:26 AM   #3
Andrea91
Thank you for your answer.
The steering wheel in the first link comes with the airbag.
Will go to the dealer to check what's needed to retrofit mfc.
xbimmers
