06-10-2018, 07:32 PM | #1 |
Rep 40
Automatic seat adjustment between driver profiles
My wife and I both drive the car. When I open the door with my key in the pocket, the seat will adjust to my preset position. But when my wife open the door with her key in the pocket, the seat doesn't adjust. It's the correct profile linked to the key. She can press memory seat button to recall the position. What's missing in the profile setup? Thanks.
06-20-2018, 10:49 PM | #3 |
Rep 305
Check the settings in idrive for her key. Each key requires you set up all the idrive settings separately. Maybe it's not activated for that key? I cant recall if the option selected was seat recall or if it was last seating position. Either way, check idrive settings with her key in the car...if the option is there you should be able to find it. Otherwise, I'm not remembering the setting correctly.
06-21-2018, 01:32 AM | #5 |
Rep 287
Drives: '22 X4 M40i / '24 X5 M60i
If I recall correctly, you need to use 2 drivers' profile from the iDrive and assign your key to profile #1 and her key to profile #2. Then under each profile setting, tag the option to remember the last seat position.
Make sure only one key is on the person opening the drivers door and the seat, steering wheel and mirrors should adjust accordingly. The drivers' profile screen should be opening on iDrive right away by default after unassigned key is detected, which is annoying, so most people just disable this option. You can recall it in the settings, if needed. |
06-21-2018, 12:02 PM | #7 | |
Rep 181
All I can say is stay with it. Keep trying different settings, review the owner's manual very carefully, be patient as you try new settings, and you will eventually learn the logic of this feature (which I really like a lot). Incidentally, my wife's car is a 2015 Z4. This feature works perfectly in her car. We never had an issue with this feature in her car. Still can't understand why her Z4 works perfectly and my X5 does not. Maybe it is a built in Germany thing (oh, and her headlight auto hi-beam feature works perfectly as well, my X5 is a little slow going to and from hi-beams). |
06-21-2018, 06:18 PM | #8 |
Rep 1,201
You need to check the "remember the last seat position" in iDrive for the car to return to your wife's seating position when she uses her key to unlock the door.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
