04-01-2018, 10:53 AM | #1 |
Rep 472
coating
yesterday i did full decon - iron-x followed by glide/nanoskin then followed by eraser; today will apply cquartz uk and cquartz gliss! then pray its not raining tomorrow. sometime later i'll coat the wheels and for the record I HATE CLEANING WHEELS! i wish i had curing infrared light set up.
04-01-2018, 07:50 PM | #2 |
Rep 472
that was a chore. my 1st time using cquartz and wishing i had used optimum gloss coat instead. optimum is a much quicker process, less time wiping off, & faster flashing.
04-02-2018, 11:02 PM | #5 |
Rep 472
thank you! a lot of work. i wasn't expecting to polish it but i had to. not sure if dealer quick waxed it but when i was trying to prep it i was getting smudges. polishing adding another couple hours. prob the nicest it will ever look!
04-04-2018, 07:48 PM | #6 | |
Rep 57
04-04-2018, 09:20 PM | #7 |
Rep 472
i don't have a good reason for choosing cquartz and if i had to do it again i'd use Optimum Gloss Coat because its a faster process. i assume that these products are all pretty similar... based on my visual memory i think the look of the cquartz w/ gliss and optimum gloss coat are pretty much the same.
05-15-2018, 05:33 PM | #8 |
Rep 51
Anyone has experience with Gyeon Pure? I'll be picking up my car through the European Delivery and I want to see if there is a coating I can quickly apply that can protect my car while I'm there and during transit back from Germany.
I need something that I can apply in an hour or so in a single step. Thanks. |
05-16-2018, 10:44 PM | #9 |
Rep 472
The issue isn't the time it takes to apply. You could very easily put a number of coatings on in an hour. Problem is you need to prep the surface then it needs to cure. I think the minimum time to accomplish all that would be 12-15h.
