10-07-2017, 12:18 PM | #1 |
Rep 44
Normal/Abnormal CEL Codes on a Tuned S55
I want to create this thread so we can all post up codes and help each other figure out what's "normal" and "abnormal."
I figure I'll go first: ER DP's, JB4, MSR charge pipes, and Eisenmann exhaust currently installed. Running map2 with 93 octane and so far these codes have showed up after about a hundred or so miles of driving: 102001 Air mass, plausibility -- Tuner code, ignore; NORMAL 102E11: No description found; not sure if this is normal 102901: No description found; not sure if this is normal 118001 Mixture ECU: mixture too rich; not sure if this is normal 118102: No description found; not sure if this is normal Tune pros. Please chime in! Last edited by jaysonz35; 10-07-2017 at 12:25 PM.. |
10-07-2017, 12:40 PM | #2 |
Joint Chiefs of Staff
4918
Rep 115,980
102001, 102901 these codes mean the DME is seeing more or less airflow go by the MAF than expected. This is normally caused by an aftermarket intake system. It could also just be from really high power levels though.
102E11 means the MAF sensor is unplugged or damaged. The other two 118 codes are mixture lean codes, normally caused by E85 mixtures. Mike |
Whatcoloristhat66.50 SOLIDM460.00 |
10-10-2017, 10:39 AM | #4 |
Rep 315
I've got two that are recurring - HEX Stage II Tune - No Cats - NO CEL for 20K miles, and now suddenly, I get:
P0036 - HO2S - Heated oxygen sensor 2 bank 1 P0056 - HO2S - Heated oxygen sensor 2 bank 2 I clear them and they return. I've just continued to drive with the CEL - no noticeable difference in performance. I think these are definitely DP-related, as Sensor 2 is post-cat. So, I'm not worried about them, but curious why they've showed up after 20K... /
2016 AY M4 : SB Full Leather : HRE P104 20" x 9.5" Front / 11.5" Rear : Pirelli PZero Nero GT 255/30/20 Front / 305/25/20 Rear : CCBs : KW v3's : Active Autowerke Full Exhaust & DPs : ESS Silicon Charge Pipes : VF HEX Stage 2 : VF TCU : Status Gruppe Rear Diffuser : M-Perf Side Blades : M-Perf Front Lip : Reus Audio System : Painted Side Reflectors : Black Grill Surrounds : Black Side Markers
08-23-2018, 08:50 PM | #5 |
Rep 25
I’m getting 102901 102001 102E11 after like 5k miles after putting MHD stage 2 tune downpipes and drop in filters on my M4 2015 just started happening also I feel like I just noticed that I hear a lot of intake noise on the front windshield definitely an intake noise but it sounds similar to when you have the a/c all the way up like a rush of air but I checked the charge pipes which are stock and they don’t seem to be leaking
SOLIDM460.00 |
07-09-2019, 06:44 PM | #6 | |
Rep 195
102E11 means the MAF sensor is unplugged or damaged. so is this accurate? |
07-09-2019, 06:52 PM | #7 | |
Rep 195
06-28-2021, 12:08 PM | #8 | |
Rep 21
I run BM3 Stage 2H with upgraded turbos. |
07-25-2021, 11:02 PM | #9 | |
Rep 146
