10-02-2017, 06:49 PM | #1 |
BimmerPost Supporting Vendor
24199
Rep 190,807
Much needed BMW M3/M4 Jb4 Install DIY + Review
Description and video copied from BMW DIY Guy
Check out his youtube channel https://www.youtube.com/channel/UC7z...KOhrg2il6nYpRg This is the full installation video for the Burger Tuning JB4 module, including the bluetooth adaptor and ODBC cable run. Thank you again to the excellent customer service from Mike of Extreme Power House, and his fantastic company! Product link: https://www.x-ph.com/burger-tuning-b...3-m4-f8x-tune/ The installation is into a 2016 BMW M4 F83 with the automatic transmission, which makes it a little easier than a manual. NOTE: If you DO have a manual transmission, watch the guide I posted for the F32 JB4 installation, which will show you how to properly route the OBD cable through the firewall. The installation is really straight forward if you work carefully and take your time. Let me stress again here as I did in the video: ALWAYS disconnect your battery before doing this work! DO NOT have the battery connected, as you can damage your ECU, JB4 or both! I will also show how to attach the bluetooth module to the JB4 box so that is setup properly. I cannot recommend more highly getting the BT module and mobile app. While it isn't cheap, it gives you an amazing range of tools to work with your car, not just the benefit of reading codes and resets. Absolutely worth it. I also recommend running on map 1 to start, until you have a greater sense of what the maps mean for your setup and have read the information on those settings thoroughly. The maps 2 and above are for different modifications, fuel combinations and a number of other things. Refer to the n54tech dot com forums for information and configuration advice. Required parts and tools: JB4 with bluetooth module 10mm socket 13mm socket small pick tool or flat bladed screwdriver electrical tape or heat shrink Torx bit set and driver JB 4 Mobile android or iPhone app installed (HIGHLY recommended)
10-02-2017, 09:56 PM | #3 |
24199
Rep 190,807
Yes you are correct on the auto CEL delete
schnell1982345.00 |
10-03-2017, 07:05 PM | #4 |
Rep 156
10-03-2017, 08:47 PM | #5 |
Rep 966
10-03-2017, 08:58 PM | #6 |
24199
Rep 190,807
It does not matter whether you update or not, per Terry soon the JB4 will force you to update
10-04-2017, 02:58 AM | #8 | |
Bored at work....
890
Rep 5,391
Move to Canada 🇨🇦 ✔️👍🏻
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
10-04-2017, 10:53 AM | #9 |
3441
Rep 79,211
If anyone has the older firmware files please post them up.
I don't think you need to do that. The only way you will be "forced" to update is if you wanted new features that are only offered on the newer firmware updates. Simply don't update and you will be fine. Last edited by Jeff@TopGearSolutions; 10-04-2017 at 11:04 AM.. |
10-04-2017, 02:04 PM | #10 |
Rep 156
10-04-2017, 03:41 PM | #11 |
Rep 277
Drives: '23 M3 Competition xDrive
Are we talking about overall CEL clearing capability or just the "auto" clearing functionality here? I always have to manually clear my CEL, can't see that going away myself. I understand better if it is just the "auto" clear functionality, causing you to have to read and then clear the codes manually.
2023 Violet Blue/Fiona Red Full - M3 Competition xDrive
@violetblue_m3 |
10-04-2017, 04:33 PM | #12 |
Rep 981
Sucks too because if you ever have an issue the first thing Terry and his support staff say is to do an update. Wonder if my old firmware JB just went up in value lol
10-04-2017, 04:36 PM | #13 |
Rep 850
Or BM3
Current
15 911 Turbo S Past 03 MB E55 AMG, 16 Grigio Medio F80 M3, 11 E92 M3, 13 BRZ, 06 Evo IX, 05 350Z |
10-04-2017, 05:21 PM | #14 | |
24199
Rep 190,807
the car. You can still read and delete faults using app or via menu4 in dash.
VioletBlue_M3709.00 |
10-06-2017, 09:12 AM | #15 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
EPA hit hard. Do not update at any cost. Supposedly there is still a work around with changing country codes on the android app.
FBO-PS1 and stuff
10-06-2017, 01:36 PM | #16 |
I Rock Your Girls Box
293
Rep 662
First... nice video, and its about damn time one was updated for the JB4. As simple as this install is... its hard not to look past the automatic code clearing, but I keep asking myself is it really that big of a damn deal? From what I've read, its not like a code will pop up ever time you start the car. I guess others could chime in.
Flashes do seem like the way to go, but most threads are full of only everyone's problems, and posts stating "my car wont start what do I do?!" |
