09-22-2017, 12:03 AM | #1 |
i can haz horsepowr ??
3830
Rep 1,927
Issues with E85 - car is running very rough? Faulty fuel injector?
So it's been a little less than two weeks since I got a PI kit installed from Fuel-It, where the kit uses the JB4 as a port controller. The car ran very well on the E85 that was found near my tuner, and it had no hiccups! Pulled so goddamned hard that I couldn't believe that I could do more to it. The only issue my tuner ran into was a faulty ethanol analyser, so I had to get a new one from Fuel-It, which I did today. The analyser is supposed to go on the car next week, which is when it'll be on the dyno and should be fine tuned.
On the drive home tonight, I noticed an odd smell coming from somewhere. Then I felt the car become very jittery, and it started revving very roughly. I immediately dropped speed, opened the JB4 app, connected to my car, and started logging. Here's a link to the log I was able to record: check out the fuel trim.. that cannot be right. https://drive.google.com/open?id=0B9...UJOOXAwa1MtYmM Here is also the JB4 Map 6 settings my tuner made: After leaving the car for about 2 hours, I went back and tried turning it on. It took an extra 1 second to actually crank and turn over. The idle was extremely rough, and any sort of throttle input pissed it off and made it sound like literal gunshots were going through my exhaust (not the good kind from PTF's bootmod3 burble tune either ) After exiting the car, I noticed the smell.. it literally smelled like my car had been doused in ethanol. I know the smell because it is very distinct, and I smelled it when filling my car up only 2 days ago. So what's at fault here? Based on the smell and rough idle, I'm inclined to say that the fuel injectors are faulty and it's causing a leak, or there's an injector that's stuck open. It also explains why there have been issues with trying to accelerate hard as of late, since some older logs show that there is too much fuel being injected (low AFR's).. I guess that was sign #1, I just didn't know it then *facepalm* what else could be the issue? I'm assuming there's nothing I can do through the JB4, and will need to actually get my car inspected by my tuner to see what's at fault here. Either way, I'm very saddened since I don't think I'll be getting this car back until a few days later.. had pretty big plans for the weekend. I was even supposed to go to AutoCouture tomorrow morning to get some coding done since I want some Euro MDM and what not.. don't think that's happening anymore Alex@AUTOcouture Any thoughts or suggestions? Thank you guys.
Dakar Yellow G80 M3
Ivory White Interior @dakar.g80 #savethemanuals Gone but not forgotten: 991.1 GT3, F80 M3 ZCP, E46 M3 |
09-24-2017, 01:58 PM | #3 | |
3830
Rep 1,927
Where has CaryTheLabelGuy been!
Dakar Yellow G80 M3
09-24-2017, 02:05 PM | #4 | |
ECUTek Master Tuner
10442
Rep 1,729
Drives: F80 M3 YMB
If you can smell raw fuel, you have a fuel leak.
But, what spark plugs are you running?
09-24-2017, 04:03 PM | #5 |
3830
Rep 1,927
Yeap, just don't know where the fuel leak is. Part of the reason that I think there's an issue with the injector is because the car would start sputtering and "surging" at higher RPM when pushed hard. I know it can't be the spark plugs because they're upgraded two step colder one's recommended by PTF - the NGK 97506 gapped to 0.018 - 0.020
Dakar Yellow G80 M3
09-24-2017, 04:11 PM | #6 | |
ECUTek Master Tuner
10442
Rep 1,729
Drives: F80 M3 YMB
I can't check the logs, but what is the AFR in that range where it's sputtering?
09-24-2017, 05:55 PM | #7 | |
3830
Rep 1,927
Here's a link to the log where I recorded the sputtering/surging issue. https://drive.google.com/file/d/0B9hw2sKVJIhfM1NEeTU2WWdYbUk/view?usp=drivesdk The timestamp makes difficult to read but when I floored it it looks like to goes up to 15.1 and stays around 14.6. When the surging ends, AFR goes down to 11.9 or so |
09-24-2017, 06:04 PM | #8 | |
ECUTek Master Tuner
10442
Rep 1,729
Drives: F80 M3 YMB
The boost and AFR are pretty sporadic, but AFR below 12.0 can make the car misfire and feel like crap
09-24-2017, 07:40 PM | #9 |
Rep 469
Did you recently update your jb4 firmware? Also is your PI setup correctly? It could be running the PI at idle. Also if you do not have a LPFP you can still have issues running full e85. In my experience even 60% ethanol will have issues even with PI with no LPFP upgrade.
09-24-2017, 09:21 PM | #10 | |
3830
Rep 1,927
I've been told by numerous people that an LPFP is needed to run the kit, but again - was told by the tuner that it isn't 100% necessary until I go upgraded turbos. How many hours installation does the LPFP entail? What parts are needed? I'd like a rough estimate to know how much it's going to cost. I'm figuring I may as well do it now to avoid any further headache with E85 and PS2 in the future. Thank you for the info!
Dakar Yellow G80 M3
09-25-2017, 11:34 AM | #11 | |
3830
Rep 1,927
First thing he asked was if I recently flashed the car, and I stated no, not since I first picked the car up from him where we flashed a bootmod3 map as a BEF. He's disconnected the PI kit and the JB4, and the car is still running bad. Even with the JB4 disconnected, which is what is controlling the fuel, the car is acting bad. So I've asked him to flash the bootmod3 map again and see how it acts. Sigh, such cumbersome issues
Dakar Yellow G80 M3
09-26-2017, 03:16 PM | #12 | |
IG @bmwF9xG80
3813
Rep 7,593
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
09-27-2017, 12:38 AM | #13 |
3830
Rep 1,927
My tuner flashed the stock ZCP map the car came in - car is still running very rich and not well. He checked the fuel rail too - found nothing abnormal. PI, JB4, and bootmod3 all disabled and the car is still running poorly.
He's going to try and drain every ounce of ethanol that's in the car and fill her up with 93 octane. The hope is that it's an issue with the spark plugs that were used. Maybe they were faulty ones, but that's the hope. TPG Tuning could this really be a result of a lack of a lpfp? I'm not exactly sure of the role of a low pressure fuel pump to be honest. If the issue isn't spark plug trusted, then there's a serious "mechanical" issue with the car, to which my tuner suggested I take the car to a BMW dealership and have them diagnose it. I'm very much so against that, and would rather have AutoCouture do everything. Dealerships will severely overcharge but at least I'll have a loaner car? I'm not even sure at this point, but is it strange that I trust AutoCouture in diagnosing the issue and fixing it moreso than the dealer?
Dakar Yellow G80 M3
jeff@autocouture965.50 |
09-29-2017, 09:19 AM | #14 | |
Rep 2,809
You need to change your plugs (NGK 97506) and gap them down to 0.018 and see if this fixes it. How many miles on your current plugs? Are they stock? I've seen this a bunch of times, when plugs finally become a serious issue, the engine will misfire even at idle. |
FSociety3812.50 |
09-29-2017, 01:39 PM | #15 | |
3830
Rep 1,927
But we found out the issue - cylinder #6 has a mixture of oil and fuel in it somehow. It's only #6 too. The oil filter has also been contaminated by fuel as well. I'm currently at AutoCouture having the car inspected by their foreman. If this issue can't be fixed then the car is going back to stock and going to BMW. Also, glad to see you posting again Cary! Your feedback on any matter is appreciated by us mortals that aren't as educated and enjoy second opinions |
10-02-2017, 11:51 PM | #16 |
3830
Rep 1,927
Update:
I was right - fuel injector issue. Cylinder #6 had a faulty OEM injector and the part has been installed on my car, and the injector is spraying normally. AutoCouture will be putting parts of the car back together and make sure everything is okay tomorrow, for me to pick her up the day after. I suspected it was a fuel injector issue from day 1, but I felt it was necessary to take the car back to the last person to touch it, which in this case was TNT Racewerks located in Deer Park, LI, and have them take a look at it. The owner, Alex, is a nice guy, but he didn't come through as much as AutoCouture has. I left the car at Alex's shop for a week, hoping he'd take a look at it for free since it started acting up after he touched it, but that wasn't the case. At the end, he charged me $400, and I left his shop with knowledge that it was cylinder #6 that had an issue, and not much else. He was unable to perform a compression test to verify any cylinder issues. It is rather frustrating because he advised me to take all my mods off, order a new DME, have it coded, then take it to BMW to have them fix it. Instead, I took it to AutoCouture, their shop foreman was able to pull the plugs, inspect everything, and see the issue (took only 3.5 hours to accomplish), and we ordered an injector that very same evening. Had I done this earlier in the week, I bet I'd have my car by now, but I took it to them on Friday. I'm not sure anyone has come across my same issue after running E85, but the early symptoms of this issue are this: surging at mid~higher RPM under high load/full throttle. It'll feel like you're bouncing off a rev limiter, then it'll go after a second or so, there will be no traction control lights going off. Everything else will feel fine, so you won't suspect a misfire, or the fact that the car is running rich. If your AFR's are low, and the fuel trims are low as well, have your car checked out before it starts misfiring extremely badly and it spraying fuel absolutely everywhere Fair bit of advice to anyone looking to seriously mod their car so they don't make the same mistakes as me - take your car to a reputable shop. AutoCouture is known to charge a bit more for labour, but it's fucking worth it. Had I just gone with my gut feeling, I would've saved $400, but I was compelled to take it back to the tuner that modified it last, since it made the most sense at the time. Will report back Wednesday with findings. At this point this thread is just a log for anyone else that may run into similar issues as me haha
Dakar Yellow G80 M3
Ivory White Interior @dakar.g80 #savethemanuals Gone but not forgotten: 991.1 GT3, F80 M3 ZCP, E46 M3 Last edited by AhsanU; 10-03-2017 at 12:41 AM.. |
jeff@autocouture965.50 deli333145.00 |
10-03-2017, 09:07 AM | #17 | |
Rep 2,809
Improper tuning for full E85 is usually the culprit for the high RPM stutter guys running straight E85 (with PI) experience (beyond plug/gap issues). It can usually be fixed with proper tuning. I've been running straight E85 for many months now with ZERO port injection on my M4. Details on the latter will be coming soon. |
FSociety3812.50 |
10-05-2017, 07:27 AM | #18 | |
IG @bmwF9xG80
3813
Rep 7,593
Its not the first time I've seen cars throwing all bunch of issues after leaving that shop OP!
10-05-2017, 09:26 AM | #19 | ||
3830
Rep 1,927
Tuning-wise, the only thing he could've tuned is the JB4, correct? Do the numbers that's in there original post look fishy? Or is there no way to tell without getting on a dyno? |
10-05-2017, 03:02 PM | #20 | |
Rep 2,809
FSociety3812.50 |
10-05-2017, 03:12 PM | #21 |
Rep 885
10-09-2017, 09:23 AM | #22 | |
BimmerPost Supporting Vendor
966
Rep 13,780
