09-20-2017, 01:15 PM | #1 |
Rep 444
Gintani Crank Hub
Has anyone seen this from Gintani...A little different than PSI
Our complete one piece crank hub solution is almost ready. Special tooling and hours of design and engineering has gone into this part. This is not a multi piece part that has weak points this will hopefully be the end of the evil spun crank hub issues. #gintani #gintanibuilt #madeinhouse #madeinusa #bmw #bimmer #m #m4 #m3 #f80 #f82 #gootboost #nomorehubspin #designed #engineered #builtbygintani https://www.revvolution.com/image/al...th-228613.jpeg
2017 Mineral White M3
Mods to COME |
09-20-2017, 03:03 PM | #2 |
Rep 656
Its been almost ready for 18 months.
Let's see one with the chain around it. I would like to know if they altered the tooth profile or not. Also what modifications to the chain guard are necessary to install this? If it fits without causing premature wear on the chain, it will be good. It looks good.
///M4 | AKRA Evo & DP's | Brembo GT BBK | MSR CAI & CP's | MPSC2 |
Suspension : | KW CS 3-way | Dinan Toe Links | GC ARWJ & End links | IND Shims | SPL Control arms & End links | aFe Bars | |
09-20-2017, 03:09 PM | #3 |
ECUTek Master Tuner
10442
Rep 1,729
Drives: F80 M3 YMB
IMO, it looks like the most promising design
09-21-2017, 09:07 AM | #5 |
ECUTek Master Tuner
10442
Rep 1,729
Drives: F80 M3 YMB
09-25-2017, 03:25 PM | #6 |
Rep 2,997
....Can you link/show the timelines on the last 5 spun crank hubs we are aware of on this forum?
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
09-25-2017, 04:03 PM | #7 | |
ECUTek Master Tuner
10442
Rep 1,729
Drives: F80 M3 YMB
Im sure Google can
09-25-2017, 05:22 PM | #8 | |
Rep 236
If it's not a concern of yours why check in on this and every other thread concerning possible crank hub solutions? Don't mind me. I'm over here like -_- Last edited by Uponone76; 09-25-2017 at 05:40 PM.. |
Arcades8174.00 |
09-26-2017, 12:32 AM | #9 |
Rep 502
I have spun twice this year. One engine lost and one slip that caused timing to jump 45 degrees and caused exhaust vanos failure. The issues is real if you are pushing the platform.
Sunset Orange G20 M340i
PAST F80 LCI/M3/AW FBO BM3 Cary Tuned Meth/Pure Stage 2 F36 CB 435i FBO F15 GS X5 50i Tune F10 AW 550i Loaded/Tune/M5 Exhaust |
09-26-2017, 05:36 AM | #10 | |
Rep 2,108
And were you driving the car in a particularly aggressive manner (such as redlining, or pressed the kickdown etc) when the incident happened or just cruising?
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
09-26-2017, 08:04 AM | #11 | ||
Rep 502
Crank Hub Spun On New Bedplate Design http://f80.bimmerpost.com/forums/sho....php?t=1420455
hellrotm4142.50 |
09-26-2017, 11:22 AM | #12 | |
Rep 2,997
So far it appears to be very uncommon but real on tuned S55s only - which is odd, quite frankly, but there it is.
963mw331.00 |
