09-08-2017, 03:10 PM | #1 |
Rep 89
Mpe muffler water leak....is this normal?
Hey guys, I just found my Mpe leaking water in the middle of the mpe muffler. Pic attached. Any thoughts? I did't find any cracks on the side of muffler. Also my Mpe rattle a bit around 1000 rpm after I coldstart. Plz help
09-08-2017, 03:50 PM | #4 |
Rep 89
09-08-2017, 03:56 PM | #5 |
Rep 908
At cold start mine had a rattle when I got it but I tightened the bolts in the tips and the rattle stopped completely.
09-08-2017, 04:43 PM | #6 |
Rep 2,711
That looks to be a little bit more than the average condensation found in all exhaust systems. It's best to have a dealer inspect it for possible defects.
09-08-2017, 04:51 PM | #7 |
Rep 1,984
Its cracked and the exhaust is leaking water/condensation out of it, although I think that is the first I have seen crack in that spot. Just another thing to add to the list of fucked up MPE problems (cracking, rattling, being an over all POS).
And this is coming from an MPE owner. |
09-08-2017, 06:28 PM | #9 |
Rep 1,984
09-08-2017, 09:26 PM | #10 |
Rep 908
Why sad? Should be covered under warranty
09-09-2017, 06:46 PM | #11 |
Rep 1,984
Because BMW won't warranty without a receipt or some kind of proof of install by a BMW dealership. So second hand owners are SOL.
09-09-2017, 07:05 PM | #12 |
Rep 908
He only had it for 3k miles so hopefully he has what he needs to be covered.
09-10-2017, 01:10 PM | #14 |
Rep 89
I don't know whether my mpe is hit by something or not. But there are two dent lines up straightly in the middle of the muffler and two dents are finished evenly. So IMP, these to dent are originally on the brand new muffler. Any MPE users have this kind of dent?
09-10-2017, 01:12 PM | #15 |
Rep 89
09-10-2017, 01:39 PM | #16 |
Rep 1,336
09-10-2017, 04:26 PM | #17 |
Rep 154
Drives: '16 SO M4
I don't see how you could have hit something and not known. It would have hit other undercarriage parts and your front bumper. That would be odd because I'm sure it would make noise and you would have noticed. You can ask and deny you hit something especially if you don't know. Why admit to it if you can't definitively say you did?
09-10-2017, 06:18 PM | #18 | |
Rep 89
09-10-2017, 11:36 PM | #19 | |
Rep 908
09-10-2017, 11:45 PM | #20 | ||
Rep 908
I would take it to BMW and see if they would replace it under warranty. Would be cool to have a brand new one!
09-10-2017, 11:45 PM | #21 |
Rep 1,055
That isn't a dent. It's there on both of the MPEs I've had. Mine was replaced under warranty for splitting on sides. You don't need to have cracking to have rattling. Others have had stuck valves.
When I had my cracks, moisture was coming out of them causing the white crust you see there. It does appear you may have a crack, but as someone else has posted, that isn't a common area where cracking occurs. If you have all of your papers in order, just take it to the dealer and have them check it out. Last edited by damageprone; 09-11-2017 at 09:28 AM.. |
