08-12-2017, 09:35 PM | #1 |
Rep 200
Drives: F80 M3
Bootmod3 problems
I've had the bootmod3 stage 2 93 octane tune for the las 3,000 miles and it's been running great. I decided to try out e85 and loaded up the HSTG2 E40 map and the car runs like complete crap! The car sputters and hesitates at anything over 50% throttle. No engine codes but it it running terrible. On one of the pulls the car just started sputtering and hit a wall at 6500rpm and just kept bouncing around at that rpm, not accelerating. No matter what gear the car sputters at wot. Any ideas what could be the problem?
F80 M3
Full E85 tune by F80Paul || AR downpipes || Signature Wheels || BMS intakes INSTAGRAM: @850_f80m3 |
08-12-2017, 09:46 PM | #3 |
Rep 200
Drives: F80 M3
That's what I thought because I added 6 gallons of e85 that tested at 80% ethanol to top of my tank of 93. Car ran like crap so I added 2 more gallons of e85 once the tank was at about 3/4 like an idiot. Car ran even worse after that so I have since added about 7 gallons of 93 to dilute the mixture and the car still runs terrible.
F80 M3
08-12-2017, 09:49 PM | #4 |
Rep 179
Iirc ethanol is heavier than gasoline, so you may still be getting a more e85 rich mixture. I'd say switch back to the 93 file and drive conservative until you can fill back up with 93. If you did any damage you probably wouldn't have a running car right now, so at least there's that, lol.
08-12-2017, 09:57 PM | #5 | |
Rep 200
Drives: F80 M3
F80 M3
08-12-2017, 10:00 PM | #6 |
Rep 179
If it were my car I'd run ir dry and fill it up with the 93 on the 93 file to make sure nothing else is wrong. Then once you're down a few gallons try out an e30 mix.
08-12-2017, 10:04 PM | #7 |
Rep 200
Drives: F80 M3
Yeah I'm gonna give that a shot. I figured since it's an e40 tune I should put in that mixture but is it safe to run that map on just an e30 mix?
F80 M3
08-12-2017, 10:51 PM | #9 | |
Rep 1,095
2016 M3 Alpine White / Sakhir Orange BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount) |
FSociety3812.50 |
08-12-2017, 11:43 PM | #10 |
Rep 200
Drives: F80 M3
Yeah I opened a support ticket yesterday afternoon and haven't received a response yet. I did a couple of logs. How do I post them here?
F80 M3
08-12-2017, 11:44 PM | #11 |
Rep 200
Drives: F80 M3
Once this take is empty I'll give that a shot!!
F80 M3
08-13-2017, 12:05 AM | #12 |
Rep 1,117
I know this completely irrelevant but are you located in Tallahassee? Asking bc i saw the 850 in your name and in need of m friends
08-13-2017, 12:25 AM | #13 |
Rep 200
Drives: F80 M3
Yeah I'm actually in Tallahassee for school. Are you the guy that drives the blue m3 at tcc?
F80 M3
08-13-2017, 08:47 AM | #14 | |
Rep 2,809
08-13-2017, 11:43 AM | #15 |
Rep 1,117
YESSSSSSSSSSSS OMFG!!!!!! Broooo let's link up I also hv BM3 and full cat back exhaust now! Do you go to FSU or tcc?
08-13-2017, 12:49 PM | #17 |
Rep 200
Drives: F80 M3
TCC this semester then FSU in the Spring. I had that cammed blacked out Camaro 1LE that you ran in to a while back
F80 M3
08-13-2017, 12:50 PM | #18 |
Rep 200
Drives: F80 M3
Yes, I haven't messed with the plugs at all.
F80 M3
08-13-2017, 01:42 PM | #19 | |
Rep 1,117
08-13-2017, 02:50 PM | #20 | |
Rep 1,184
08-13-2017, 03:08 PM | #21 |
Rep 200
Drives: F80 M3
Yeah I know now. I was saw someone on the forum running bm3 e85 maps and they said they were running e60 so I thought my mix might have been to low. Now I know.
F80 M3
08-13-2017, 03:11 PM | #22 |
Rep 200
Drives: F80 M3
Do you run the e85 at the sunoco on gaines? Cause either their gas is bad or my mix is way off. What did you gap your plugs to? I miss the camaro kinda but I had to get a more subtle car for a few reasons. I'm gonna try and get a C7 Z06 soon, just gotta see if my insurance will cover me on it first lol
F80 M3
Full E85 tune by F80Paul || AR downpipes || Signature Wheels || BMS intakes INSTAGRAM: @850_f80m3 Last edited by 850_f80m3; 08-13-2017 at 03:50 PM.. |
