08-08-2017, 12:44 PM | #1 |
Rep 334
Boost Pressure Lower Than Expected Code
So I was doing a pull against my buddies GT-500 going from 3rd to 4th Gear (6-Speed Manual, JB4 Map 2 all wires connected) second I shift to 4th gear, loss of power then I got a drive train malfunction. First thought is I cracked a charge pipe, when I got back checked all the pipes and they seem fine no cracks. Turn the car off let it sit for 20 minutes, start it back up and the code is gone and the car seems to be running fine. Could this be a problem with the turbo's waste gates or just a fluke, should I be concerned?
120308 Boost Pressure Lower Than Expected |
08-09-2017, 11:48 PM | #3 |
I Rock Your Girls Box
293
Rep 662
Is this the first pull on the JB4?
If so, pull the negative on the battery and let everything relearn. I know the JB4 had your back, but give it time - and you will love it. |
08-10-2017, 11:05 AM | #4 | |
Rep 674
Probably not the issue but try unplugging the EWG connectors since they're not needed for MAP 2 anyway. |
08-10-2017, 12:00 PM | #5 |
Joint Chiefs of Staff
4918
Rep 115,980
Do a datalog and evaluate if your boost is really below target. If it is then continue looking for physical boost leaks, etc.
Mike |
08-14-2017, 06:32 PM | #7 |
BimmerPost Supporting Vendor
24201
Rep 190,807
+1 for datalog
03-27-2023, 10:32 AM | #8 |
Rep 92
Was this ever resolved? Just had a similar situation on my M8 Comp.
Rides--
'17 M3 CP-CAI, Dinan Stg 1 '17 Camaro ZL1 (700HP) '15 Audi S4 (500 HP) '15 Charger Hellcat (1050 HP) |
