08-07-2017, 03:31 PM | #1 |
Rep 3,670
Eisenmann Exhaust Install
Hey guys, I just got the Einsenmann Resonated full exhaust installed.
I swapped from the AWE exhaust, not from stock. We couldn't get the valves to work yet on the Eisenmann b/c it needs the valve springs from the stock exhaust. I just got home, and I'm looking at my stock exhaust. It has what I believe is needed. Does anyone know how to take it off? Appreciate the input |
08-07-2017, 04:51 PM | #3 |
Rep 3,670
08-07-2017, 06:36 PM | #4 |
Rep 3,670
update:
After looking at the official instructions and seeing what's there, I think I'm missing a very small piece of metal that the spring goes around. Any ideas?
08-07-2017, 08:06 PM | #5 |
Rep 919
It's referring to two pieces that came with the exhaust it's not from the stock exhaust. they look like curved paper clips. They basically act as a bridge between the new valve and the stock actuator , they are in the install instructions on the USB shaped like a key.
2018 F80 ZCP 6MT YMB/SO 2015 F82 M4 6MT AW/SO - SOLD Last edited by PayamFSU; 08-07-2017 at 08:22 PM.. |
08-07-2017, 08:24 PM | #6 |
Rep 919
can you do me a favor once you get these connected can you take a picture of your exhaust valves in the "open" position (both sides) please, I want to compare it to mine, because they are not equal on both sides on mine in terms of the degree in which they are open.
2018 F80 ZCP 6MT YMB/SO 2015 F82 M4 6MT AW/SO - SOLD |
08-07-2017, 09:35 PM | #7 | |
Rep 3,670
If anyone knows where to get replacements, that would be helpful too |
08-08-2017, 01:39 AM | #8 | |
BimmerPost Supporting Vendor
1267
Rep 869
It looks like this this. You will need two.
Speed & Tech Motoring
23585 Overland Drive, Unit 178 Sterling, VA 20166 (Headquarters) 23541 Pebble Run Place, Unit 140 Sterling, VA 20166 (Satellite shop) |
08-08-2017, 02:00 AM | #9 |
Rep 3,670
08-08-2017, 06:38 AM | #10 | ||
Rep 919
08-08-2017, 06:40 AM | #11 | |
Rep 919
08-08-2017, 08:13 AM | #12 | |
1267
Rep 869
08-08-2017, 08:15 AM | #13 | |||
1267
Rep 869
08-08-2017, 11:37 AM | #14 |
Rep 3,670
Alright as usual, Steve Thomas BMW was charging me twice as much as Rusnak BMW for the same part (lol)
I hope to get all this fixed today. Wish me luck |
08-08-2017, 01:49 PM | #15 |
Rep 3,670
Thanks Jesal from IND, the instructions are very helpful!
IND-Distribution9587.50 |
08-08-2017, 03:01 PM | #16 | ||
Rep 481
08-08-2017, 04:45 PM | #17 |
Rep 3,670
This piece is from a X6. It's not standard on our cars. The Eisenmann is the only exhaust I know of that uses this clip (I've had almost every exhaust made our cars including the Akrapovic, Dinan, AWE, MPE, Remus, IPE, and Magnaflow)
08-08-2017, 08:45 PM | #18 |
Rep 3,670
Alright, the install went successful!
Now my first impressions on the Eisenmann: Flow is definitely there, but the way it handles rasp and drone is very civil. Downpipes are a great addition to this IMO, Resonated exhausts are too quiet with stock downpipes Last edited by aBMWfan; 08-08-2017 at 08:58 PM.. |
08-08-2017, 09:06 PM | #19 |
Rep 151
mind to share your opinions for other exhausts you have tried?
08-08-2017, 11:14 PM | #20 |
Rep 3,670
If you have ZCP, you can't go wrong with MPE or AWE they're both great. IPE is loud but sounds aggressive (not good with downpipes). Remus is drony with valves closed, similar to IPE w/ valves open (Aggressive). Akrapovic EVO, Eisenmann Full, and Dinan with the Remus Resonated Midpipe were all similar (quiet with valves closed, sound amazing with valves open, can pair well with downpipes). Magnaflow was very good on the low end, doesn't sound great on WOT.
08-09-2017, 10:03 PM | #21 |
1267
Rep 869
Don't think it can fall out that easily. It was the source of valve rattles on my Eisenmann exhaust (don't think any other exhaust uses these fixing bows). I had a lot of rattling under load, what i did was bend the bow outwards a bit so it would create more pressure, valve rattle hasn't happened since.
