07-25-2017, 08:50 PM | #1 |
Rep 244
MPE Muffler quieter than Stock muffler
Anyone here using aftermarket midpipe like AA with MPE axelback muffler? If so did you notice that MPE is quieter than stock exhaust? After speaking with my installer, we think it may be caused by the smaller pipes in the middle (the outsides are same size as stock.)
Tone is definitely better with the deepness and raspiness, but volume was disappointing. |
07-25-2017, 09:16 PM | #3 |
Rep 244
07-25-2017, 10:15 PM | #4 |
Rep 908
I have a different mid pipe paired with my MPE. It's awesomely louder.
07-25-2017, 10:20 PM | #5 |
Rep 244
07-25-2017, 10:34 PM | #6 | |
Rep 908
Also, the MPE pipes slide over the stock pipes so they have to be the same size or slightly larger than stock at least where the pipes connect.
07-25-2017, 10:55 PM | #7 | ||
Rep 244
With the understanding that "usually" midpipes affect volume and mufflers affect tone, one would guess that MPE muffler would only affect tone, but in my case it affected both tone and volume. From speaking to a few people this may be caused by the size of the smaller pipes in the center of MPE which is about 1 inch smaller than the stock mufflers middle pipes. And to a lesser degree the MPE tips since they are resonated. Hard to say, but from all the exhaust shops I spoke to before install, the middle pipes on MPE muffler is uniquely small compared to almost all other exhaust systems they worked on. So the reason why order matters in your case is because you are essentially comparing MPE midpipe vs an after market midpipe which the after market one will almost always win in terms of loudness since BMW has to design their midpipes to meet certain codes where after market can get away with a little more. What I really want to compare is how does the MPE muffler affect the volume vs other mufflers |
07-25-2017, 11:51 PM | #8 |
Rep 151
I found the sound was quieter then stock zcp after installing the AA mid pipe, but after three weeks, it sounded definitely louder and deeper... I asked that on the forum, and thought there was something wrong with installation, but looks like AA mid might have to adapt with mufflers sometimes
07-26-2017, 09:12 AM | #10 |
Rep 244
Keep me in the loop, is like to know your thoughts. Did you have a different muffler with aa mid pipe before switching to MPE
07-26-2017, 09:13 AM | #11 | |
Rep 244
07-26-2017, 11:30 AM | #12 | |
Rep 1,030
JD |
07-26-2017, 12:12 PM | #13 | ||
Rep 244
Either way the tone did change and has a lower more throaty sound but volume on my install was definitely softer |
07-26-2017, 01:45 PM | #14 |
Rep 151
my case was especially softer then before at cold start...and I think right now it is still just at the same level as before when cold, just when it warms up, everything becomes sweet
07-27-2017, 03:27 AM | #15 |
Rep 1,030
hexone is your car this loud? Seems like he has the exact same setup I'll have. And it seems that the top end of the MPE with AA Midpipe gets rowdy. Low end might not be so different.
07-27-2017, 10:45 PM | #16 |
Rep 244
Yeah, hard to tell the volume but it sounds similar. Car is still decently loud, just not as loud as it used to be.
07-27-2017, 11:13 PM | #17 |
Rep 908
Are you running in Efficient mode or Sport mode do you know if the valves are open or closed?? Did you check to make sure they were installed correctly/are still working? When the flaps are open the exhaust is practically straight pipes whether using the MPE or the stock muffler.
07-28-2017, 12:13 AM | #18 | |
Rep 244
07-28-2017, 08:26 AM | #19 | |
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
that being said, I personally want my MPE to be louder as well.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
07-28-2017, 11:13 AM | #20 | ||
Rep 908
07-28-2017, 01:02 PM | #21 | |||
Rep 244
