BMW M3 Forum (E90 E92)
EXXEL Distributions
      07-23-2017, 11:09 PM   #1
e92m333
Drives: e92 m3
Track coilover and setup suggestion??
Hi guys. I have e92 m3 with ohlins R&T coilovers. Lately i upgraded my oem ohlins springs to 600 spring rate front and 800 at the back. Car has 1.3 negative camber in front Car has ess650 kit as well.
Well car has no body roll now but its more stiff now. When i brake hard on track it slides. When i turn it over steers a bit.
Question is that should i play with dampening? Or u think springs are too stiff for ohlins without revalving? Should i go back to oem springs with little bit stiffer springs in front? Should i put more camber in front and at the back. I run good track tires too. Im confused what setup to run at the track. I track hard .
Power wise i have no issues with ess kit. Its just the suspention im stuck with. If anyone can give me a best track setup advice i will be very thankful to you plus i will pay if your advice worked on mg car.
Thanking you in anticipation
      07-23-2017, 11:10 PM   #2
aus
Drives: Odysse
You'll probably get more in the track section here. It's pretty active.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      07-23-2017, 11:54 PM   #3
elim11
Drives: e90m3
There are a lot of factors at play here. Are you braking in a straight line or are you braking while turning?
How is your alignment and when did you get it set up last. -1.3 is pretty OEM, should have a lot of tire contact patch.
      07-24-2017, 05:27 AM   #4
nicksm3
nicksm3's Avatar
Drives: e92 m3 Competition
Yes many factors as stated by the member above. Also,
1) running a BBK?
2) What sway bars are you running?
3) Tire pressure?
4)What's your alignment besides front camber, ride height? Toe? Pretty much all of it.
Just because a car is stiffer doesn't necessarily means it "best" for handling/tracking.
      07-24-2017, 12:00 PM   #5
e92m333
Drives: e92 m3
1) running a BBK?
3) Tire pressure?
no bbk. oem rotors and pads
stock sway bars
30 psi hot tire pressure
ride heights is90 % slammed at the back and 60% in the front
      07-24-2017, 12:04 PM   #6
e92m333
Drives: e92 m3
allignment was done months ago.
braking in straight
      07-24-2017, 12:10 PM   #7
Datka
Datka's Avatar
450
Drives: 2009 M3 ,2021 M340i
I have Ohlins R&T with camber set -2.8-F/2.0-R. Didn't upgrade springs to a higher rate but did notice some body roll and understeer even with -2.8 front camber. Dinan front bar fixed that and now car feels good in high speed braking and high speed transitions.
You have to remember, this is not a hard core set up, but it is a huge upgrade from the stock susp.
In soft settings it feels as good or better as stock, go stiffer and it feels great on the track.
If it was track only car I would go with MCS coilovers no doubt.
In your case, I think you definitely need at least 2.8-3.0 neg camber up front and a stiffer front bar.
Still may not be enough for those dampers with your ESS kit. Keep in mind, that kit adds about 100 pounds to the front of the car
"Racing is life. Anything before or after is just waiting." Steve MCQueen
      07-24-2017, 08:22 PM   #8
slicer
slicer's Avatar
2739
Drives: 'E46 M3 Race Car, '23 X7
You definitely need more front camber. At least -2.5. I run -3 front and -2 rear. I'm still working out the kinks on my car (new build) so I can't tell you the exact best camber settings but I can say that it did feel neutral on my last track day.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      07-29-2017, 01:25 PM   #9
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
This is an easy one ...your suspension is too way too stiff. You need body roll, nose dive and squat to get the tires to work. Otherwise, your car is basically a chassis riding in cinder blocks.
Has nothing to do with alignment.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      07-29-2017, 04:21 PM   #10
cenix
cenix's Avatar
Drives: E90 M3 ZCP
^ that's pretty much the answer but I was kind of thinking it was a troll thread (no offense OP) because if he's "tracking hard" with a supercharger I'd think the -1.3 camber and Ohlins R&T with good track tires are already bad choices.
      07-31-2017, 10:21 PM   #11
doogee
doogee's Avatar
748
Drives: '08 M3, '09 328xi Sport Wagon
Focus less on setup and parts and sign up for a driving school. You'll learn a lot and go faster than messing with setup.
You're probably overdriving or not driving smooth. An in-car video would help more than listing your mods etc.
      08-24-2017, 02:31 PM   #12
e92m333
Drives: e92 m3
thats actually a good advice. i think you are right.
but i am looking for coilover advice for the time being.
      08-24-2017, 04:20 PM   #13
lutfy
lutfy's Avatar
254
Drives: G87 M2, NASA ST5 86, Defender
With those options, you will go round and round trying to figure out what is going on.
Luckily you are next to one of the hottest shops out there:
http://www.ravenperformance.com John Dimoff is a good guy and builds some of the fastest BMWs (track performance/C Mod Race cars) out there. Trust those guys.
Lutfy
      08-25-2017, 11:41 AM   #14
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
No amount of coil over advice is going to fix what is wrong, when what is wrong is not with the car but the wetware that operates it.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
      08-25-2017, 01:27 PM   #15
rhyary
rhyary's Avatar
Drives: 2013 M3
30 psi Hot?
Try 38 hot
m3post
