07-18-2017, 07:54 AM | #1 |
Rep 199
Help I need a photo of the internals of the standard or CP exhaust
Hi can anyone help?
I'm looking to modify a spare CP exhaust I've bought for my car and I'm trying to understand what is inside the silencer and if it is worth cutting it open to make changes to the interior or not. If anyone has done this already and has a picture it would be most appreciated thanks. |
07-18-2017, 11:56 AM | #2 |
Rep 1,555
Check the intro to the new M3/M4 thread. There are drawings of the complete oe system. I'm about to begin looking for another oe exhaust as i want to also modify the oe can (to reduce weight). I've already removed the secondary cats and the car sounds great (for me anyway).
07-18-2017, 12:24 PM | #3 |
Rep 1,555
Here's the link BTW http://f80.bimmerpost.com/forums/sho...d.php?t=979417
07-18-2017, 03:01 PM | #4 | |
Rep 199
Thanks thats really helpful. I'm speaking to an exhaust fabricator and I'm planning to remove the secondary cats and weld in straight pipes and we might replace the resonator centre box with an x pipe. The fabricator talked about opening the rear box and replacing any perforated pipes with straight pipes. As I have the exhausts set to open in the exhaust I don't see any advantage of doing this as it seems the gases exit without going through the rear silencer when the flaps are open......am I right or should we be modifying the rear box as well? |
07-18-2017, 03:08 PM | #6 |
Rep 199
07-18-2017, 03:13 PM | #7 |
Rep 199
Thinking out loud and anyone please let me know if this is a stupid idea but as I run with the flaps open all the time could I just get the fabricator to cut the rear box away completely and weld up the pipes that feed into it? Gets rid of the weight and the ugly dustbin rear silencer?
07-18-2017, 03:21 PM | #8 | |
Rep 6,863
jim996126.50 |
07-18-2017, 03:57 PM | #9 | |
Rep 199
07-18-2017, 05:31 PM | #10 | |
Rep 1,555
I also have removed the secondary cats and am loving it. My next idea is to cut the OEM muffler and make a "slim" design to reduce weight and improve areo at the rear. If you've seen the mufflers front side you'll know what i'm talking about. This is low on my priority list though. I also thought making the diameter of the valve cutout section larger. This should help the flow as the volume of gas flow is currently restricted by the ID + the valve shaft even when the valve is open. I look forward to your review of the secondary cat + mid muffler replacement with X-pipe! |
07-19-2017, 03:10 PM | #11 | |
Rep 199
