07-01-2017, 08:16 AM | #1 |
Rep 16
f80/2 M3/4 Exhaust Valve Delete Kit Installation
07-01-2017, 09:54 AM | #3 |
Rep 155
Why not pull fuses 146 and 147 for free? Everything stays connected, no worries about debris and doesn't cost a penny. Forgot who posted this originally, but I did it last week and works great.
BMthusiast779.00 |
07-03-2017, 04:52 PM | #4 |
Rep 11,760
Drives: 2018 M4 Comp Indv
or just pull the plugs and duct tape them.
10-27-2018, 05:26 PM | #5 |
Rep 375
Drives: 2020 M2C DCT
Here are the part numbers:
Universal socket housing uncoded This is the connector that goes into the exhaust flap actuator to protect it from corrosion. This part number doesn't include the cavity plugs. I'm trying to find a part number for the cavity plugs, but you could use silicon caulking. Dummy flap actuator This is the dummy plug that is connected to the wiring harness to prevent a code. |
02-21-2019, 11:05 AM | #6 | |
Rep 51
02-21-2019, 12:11 PM | #7 | |
Rep 369
https://www.ecstuning.com/b-genuine-...r/18302411427/
///M3
02-21-2019, 02:03 PM | #8 | ||
Rep 51
Any other bmw component / part websites we can look at? The part does not fit the bmw m4 as stated on the web link |
02-21-2019, 08:26 PM | #9 | |
Rep 369
this to not throw a code) so I bought it. ECS is just behind in their compatibility labeling. I already spoke to their customer service department about this. They also mislabel the 6mt drain/fill plug that this car needs as not being compatible.
///M3
02-21-2019, 08:30 PM | #10 | ||
Rep 51
02-24-2019, 10:13 PM | #11 | |
Rep 375
http://www.realoem.com/bmw/enUS/partxref?q=61138364614 http://www.realoem.com/bmw/enUS/partxref?q=12527549033 |
02-24-2019, 10:27 PM | #12 | ||
Rep 51
10-28-2019, 02:18 AM | #13 | |
Rep 105
so just buy two of each ? socket housing (12527549033) and exhaust flap actuator (18302411427) for both sides? hard time visualizing what does the earlier poster mean its missing cavity plug (61138364614) if that's needed, how many needs to be bought? |
11-09-2019, 06:45 PM | #14 |
Rep 375
For each flap that you want to disconnect, you need one dummy plug (goes on the end of the wiring harness to prevent a code from being raised), one socket (goes on the flap in place of the connector from the wiring harness) and four dummy grommets (one to plug each hole in the socket). The connector has four pins, which is why you have to close off four holes. Hope that helps.
11-09-2019, 09:16 PM | #15 | |
Rep 105
