06-23-2017, 09:22 AM | #2 |
M3 Fan
209
Rep 210
Drives: F80 M3, E92 M3 and E46 M3
What year and specific model?
F80 SSII, Carbon/leather Interior, 6sp, BC Coilovers, Dinan Stage 3 with heat exchanger, Active autoworks Midpide, CF Revozsport diffuser, Mperf splitter, sideskirts, BC forged two piece wheelsE46 M3C, Carbon Black Metallic, ESR Turbine wheels, AFE catback Exhaust, Stein Springs, Bavsound, Dinan front strut brace
06-23-2017, 11:54 AM | #6 |
Rep 222
I assume if anything happens they'll just end up blaming it on bootmod.
06-23-2017, 02:21 PM | #7 | |
Rep 8,083
it would help a little if he had a decent SA and Tech to help facilitate if there is an issue. But yes. But I''m saying, since he's already flagged, might as well keep the boot mod and go from there, much more to offer than the piggy. |
FSociety3812.50 |
06-24-2017, 09:53 PM | #10 |
Rep 8,083
06-24-2017, 11:03 PM | #11 | |
Rep 340
06-25-2017, 09:52 PM | #12 |
Rep 8,083
06-25-2017, 09:57 PM | #13 |
Rep 340
well unfortunately for me I got flagged the first time I took it by my local dealership when I had an issue that required them to replace a part and re program the associated cafd...
The car was regularly serviced prior to me purchasing it at the dealership the service manager worked at, no surprise. despite this, the car was not flagged until I took it in... |
06-25-2017, 10:00 PM | #14 | |
Rep 222
06-25-2017, 10:51 PM | #15 |
Rep 340
No, they couldn't do that as the DME tune had nothing to do with the Driver's Side Restraint issue that popped up. Basically with Moss Magnuson act we have a bit of protection as consumers, they can't decline all warranty work due to something like a tune. Unless they can prove the tune had something to do with an error, they ned to fix the warrantied issue. Basically they's taken care of most things that have come up on the car since without an issue. If I were to have something like crank hub failure or something else catastrophic with the engine I'd likely be SOL as the tune would likely be pointed to as the reason the engine was operating out of normal spec and the engine failure occurred.
FSociety3812.50 |
06-25-2017, 10:59 PM | #16 | |
Rep 222
06-25-2017, 11:02 PM | #17 |
Rep 340
Not yet, although my SA mentioned they have to run all warranty repairs by BMW as a result of DME software flag in order to gain approval prior to doing the work...So far they've fixed an SRS and Airbag issue and replaced front brakes under warranty. I haven't had anything else besides routine maintenance done.
06-25-2017, 11:06 PM | #18 | |
Rep 222
06-25-2017, 11:14 PM | #19 | ||
Rep 340
06-27-2017, 02:25 PM | #20 |
BimmerPost Supporting Vendor
24199
Rep 190,807
OP,
What was the reason for the dealership visit? As mentioned above, getting flagged does not mean your warranty is voided. If you go with an engine issue, it is almost guaranteed they wont cover it under warranty. Normal maintenance will still be covered since it is unrelated.
06-27-2017, 02:27 PM | #21 | |
Rep 222
