06-21-2017, 05:05 PM | #1 |
Rep 891
Anyone with Turbo Wastegate faliure?
So a few weeks ago I was driving on the highway doing 120kmh and drivetrain error comes up, I stopped truned off the car and back on and it came up immeadetley,
So I went home to check with ISTA and it shows Electric Wastegate short circuit and after deleting it it just came back. I have BM3 Stg2 on my car for last 6 months and full Akrapovic with downpipes. I went to the dealer and after 10 days the diagnose was to replace the turbo as the error was on the electric part of the wastegate which is a part of the Turbo. They replaced ths Turbo and all is fine now now my question is has anyone had this problem and I dont know what could be the cause of this I am affraid of this happening to the other turbo as this one was not changed. Thanks, |
06-21-2017, 06:42 PM | #2 |
Rep 681
You can buy the WG separate. Part number 11657850453
However, we haven't heard of any failing. It's uncommon. |
Super Spartan1553.50 |
06-21-2017, 07:03 PM | #3 |
Rep 891
My dealer said it was not available as separate. I think he ment the electronic part of the wastegate as thats where the error was shown.
ISTA under explanation showed short circuit in the wastegate. Thanks for your answer. |
06-21-2017, 07:49 PM | #4 |
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
im dealing with it now...
edit: codes thrown were 120408 (charge pressure cntrl), 123511 (electric wastegate, wastegate valve sluggish) edit edit: my wastegate valve gets sluggish after thai food
2023 M4CSL
2005 Lotus Elise |
Shubacca121.50 |
06-22-2017, 12:59 AM | #7 | |
Rep 1,117
This is the code I'm getting "An electric wastegate fault for stop position limits" Not sure if that's the same but my car is currently at dealer getting warranted! |
06-22-2017, 07:18 AM | #9 |
Rep 626
I had these 3 pop on on mine recently. Been running BM3 since November and am kinda worried as I sent them this and they had no idea what it was or meant. Any insight in on this would be greatly appreciated.
06-22-2017, 08:25 AM | #10 |
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
i should note mine is dinan stage 3. dealer and dinan spoke and everything is under warranty. no red flag.
2023 M4CSL
2005 Lotus Elise |
06-22-2017, 10:32 AM | #11 |
520
Rep 1,026
Drives: 2018 Shelby GT350
Like Justin said, it's not a common issue for the S55 but relatively common on the N54/N55/N20 and most modern BMW engines utilizing forced induction. Like the OP had mentioned, you can technically change out the EWG on the exhaust manifolds however due to the physical adjustment factor BMW recommends to replace them as a whole(pair).
Instagram: cboy1
Justin.AutoTalent3137.50 |
06-22-2017, 11:09 AM | #12 |
Rep 891
I got only one replaced... they said the other was fine...
A question, when you are driving with dsc on or in mdm and it comes on (stops the throttle) does the excess use the wastegate? Or to simplify, if frequent driving under dsc control and interfirance is the wg/wg control being used more often? |
06-22-2017, 12:49 PM | #14 |
Rep 173
Any idea how they noticed your tune after you flashed back to the stock map ? The BM3 suppresses the tamper code so curious as to how that happened.
06-22-2017, 01:40 PM | #15 |
Rep 891
I dont know, the stock map with tamper code off was loaded... I guess if it were a normal service they wouldnt but im sure if they 'dig' over the ecu they could.
I think bmw Germany had a session wih the car. Its the risk we take when tuning the car. |
06-22-2017, 07:34 PM | #16 |
520
Rep 1,026
This statement is completely false and it's disappointing that most tuning companies will pass off inaccurate statements stating that their tunes are "undetectable" or "untraceable" because it's far from the truth. Without starting a fire, I can honestly say that no tune is untraceable and it goes back to the age old saying, if you play with fire you will get burned or quite simply mod at your own risk...
Instagram: cboy1
06-22-2017, 07:38 PM | #17 | |
Rep 387
FSociety3812.50 |
06-22-2017, 09:52 PM | #18 | |
Rep 173
Now, whether or not BMW conducts other checks to determine if the car has been tuned is a different story. I'm sure there are but the tamper code method of verification is taken care off on the BM3 end. |
06-22-2017, 10:29 PM | #19 | |
In The Rain
8174
Rep 6,259
Drives: '24 GT4RS, '24 Macan GTS
Whatever people do to make them sleep better at night.
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" |
06-28-2020, 09:43 AM | #22 | |
Rep 1
Westgate
Had 2 days ago the same problem. Malfunction number 123601 Wastegate. Just let me know, did you noticed something strange (noises,missfires,response etc.) before it happend? And also, thought it would be easier to replace the whole turbo instead of trying to troubleshoot it step by step, worth it? Currently 75k miles. BM3 st2 93. Last edited by Ahper_m3; 06-28-2020 at 12:50 PM.. |
