Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > Off-Topic Discussions Board
      06-12-2017, 05:19 PM   #1
LBBX5M
Drives: X5M F85 Akra, RaceChip
help with H1 1992 Cummins conversion
Hello I need some help please. I am looking for a reputable company that does H1 Cummins 6.7 conversion with Allison transmission and several other mods like suspensions, tires, various mechanical work. Any thoughts?
      06-12-2017, 10:23 PM   #2
KenB925
Drives: ZL1, Raptor
my only thought would be duramax, at least that v8 to v8
      06-13-2017, 07:16 AM   #3
DSB335d
Drives: '11 335d DSB/oyster&black/navi
Predatorinc.com builds the baddest H1 Hummers out there.
      06-14-2017, 07:12 AM   #4
LBBX5M
with a notorious reputation! but thanks for the suggestion.
      06-14-2017, 07:21 AM   #5
DieselOG
Spaceship Man Bad
DieselOG's Avatar
Drives: DIEsel
Not sure if these guys would work for your project but they have built the best diesel swaps I've ever seen and they do custom projects.
https://www.duramaxcamaro.com/
      06-14-2017, 05:11 PM   #6
LBBX5M
Thank you I believe their website is down for now.
Any good vibes from https://www.bigdogoffroad.com
I believe it is owned by Eric Ward.
      06-14-2017, 05:12 PM   #7
sygazelle
Are you dropping it in that X5M. More torque is always good.
      06-14-2017, 06:04 PM   #8
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
Gale Banks does some cool things with diesels...
www.bankspower.com
Lups11828.50
      06-14-2017, 06:39 PM   #9
DSB335d
Dieselsellerz.com
They also have a tv show "diesel bros" or something like that. They build some pretty cool trucks and I think they have done some H1's.
They have a YouTube channel too promoting some of the vehicles they have done.
      06-14-2017, 08:55 PM   #10
DieselOG
Spaceship Man Bad
DieselOG's Avatar
Drives: DIEsel
I believe it is owned buy Eric Ward.
Seriously, what are the chances their website goes down hours after I link it
      06-15-2017, 09:17 AM   #11
LBBX5M
I have more than enough on my X5M
I own a H1 and I want to use it as a daily driver instead of my ///M
Cattivo685.50
      06-15-2017, 10:21 AM   #12
sygazelle
It's good to be you!
LBBX5M71.00
      06-15-2017, 10:26 AM   #13
fbsm
Drives: 4wheels
I understand the attraction to the allison transmission but why not consider hitting the easy button here and going with the G56 MT or the Aisin and xfer case that the 6.7 cummings is spec'd with
That will make your life a whole lot easier and less expensive
      06-15-2017, 02:37 PM   #14
LBBX5M
Excellent point! my guess is that it could be due to the weight of the truck (which is north of 7000 lbs)?
I will be sure to ask Bigdogoffroad.com
      06-15-2017, 02:48 PM   #15
fbsm
Drives: 4wheels
That 6.7 cummins with either the G56 or Aisin are stock trannies on the 1 ton RAM which weighs 8000lbs and will carry an additional 4k in the bed comfortably and tow north of 16k
Either option will handle it all day/every day
If you were to choose the G56 MT the only thing I would upgrade is the clutch/flywheel to a south bend clutch/FW and ditch the dual mass stock solution
LBBX5M71.00
      06-23-2017, 11:48 AM   #16
Oreo Cat
Drives: E90 M3
Look up plan b supply, they rebuild real humvees. I think they start just under 30k, but 50k will get you the most options
      06-24-2017, 02:41 PM   #17
LBBX5M
Thank you! their stuff looks nice! I wonder if you have a contact there that could assist me by any chance?
Much appreciated
      06-24-2017, 03:10 PM   #18
HD F250
Drives: 2011 Frozen Black M3
Where are you located? A few of my friends are Duramax and Cummins gurus. If there is a kit, this isn't a tough conversion at all. PM me if you want more info.
      06-26-2017, 02:34 PM   #19
Oreo Cat
Drives: E90 M3
Much appreciated
I'm sorry, but I don't know anyone there. i just found it on YouTube one day and decided I must have one.. Eventually..
Tags
hummer h1, humvee
