04-10-2017, 06:47 PM | #1 |
Rep 44
Idiot Question - 18x8.5 et35 square, will it work?
Searched through the archives and couldn't find anything conclusive.
Just picked up an e88 for summer. Looking to fit 18x8.5 et35 235/40 18 Michelin PSS all around Lowering on AST 2000 series coils. Thoughts? |
04-10-2017, 07:18 PM | #2 |
Rep 1,003
Drives: 2008 BMW 135i (E88 N54 6AT)
Interested to know too.
I'm told you need 10mm spacers on the front, not sure what camber you have to run. I was considering 245/35 18's on stock coils... |
04-10-2017, 07:32 PM | #3 |
Rep 44
I'd be ok running spacers as long as this set up does not require poke or stretch to work. Oh, I also do not want to look like a 4x4.
04-10-2017, 11:08 PM | #4 |
Rep 2,347
You'll be compromising the ride with that set up. I'm lowered on TC Kline's with 18x9et38 hankook 215s up front with a 3mm spacer and 18x10et40 out back on Hankook 245s. I rub slightly up front on big dibs mid turn but nothing bad. The back is flush with fender literally no more room.
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
04-10-2017, 11:52 PM | #5 | |
Rep 44
The rims also come in 18x9.5 et35 |
04-12-2017, 08:46 PM | #6 |
Rep 95
IMHO, et35 isn't a good offset in the front or rear, especially with 235s. You'll have space inboard but it will take work on the fender side. You'd be better off above et40.
04-12-2017, 11:44 PM | #7 |
Rep 49
I ran 235/40 18 Gooyear F1 Eagle Asymmetric 2's on my E88 on 18x8 et45's with no problem. No rubbing on Koni Yellows with H&R Sport Springs and Dinan Fixed Camber Plates plus some decent negative camber in the front. No spacers and I'm not sure if PSS are really wider than the Eagles.
A couple or fifteen mods.
04-14-2017, 08:08 PM | #9 | |
Rep 351
What tires are you running? Thinking of 225/255 Direzza ZII Star Specs which should be a lot wider than their stated section widths. |
04-15-2017, 10:00 AM | #10 | |
Rep 361
Note: to fit an 8.5" front wheel, you will need camber plates to gain some significant front camber (in my estimate, -2.2 to -2.5 degrees depending on ride height assuming a 235 street tire). Front Wheel Fitment Excuse the dirt, but this is what I mean by a properly set up front coilover: That photo is a 9" wide +35 offset with a 255-40-17 Bridgestone RE71R. Here is a photo of a 8.5" wide +45 offset without tire On an 8.5" wheel with a 235, I estimate an offset of +45 would fit, but it will come down to the tire. I can guarantee anything lower than a +41 would fit as that is mathematically identical to the above fitment. Rear Wheel Fitment On the rear, you have the exact opposite problem. You have lots of room on the inside, but clearance to the fender is a challenge. I have verified that a 9" wide +45 offset with a 255-40-17 Bridgestone RE71R will just clear with -2 degrees of camber and rolled fenders. I have also verified that a 9.5" wide +45 offset with a 255-35-18 Continental DWS will fit with some extra room because the tire is a bit stretched and significantly rounder in profile. On an 8.5" wheel with a 235, I estimate an offset of +35 would fit, but can guarantee anything HIGHER than a +39 would fit as that is mathematically identical to my fitment. Summary As you can see, an 8.5" +40 is in theory the perfect square front & rear fitment that should work with certainty on front and rear as long as your alignment will fit. An 8.5" +35 will fit just fine in the front (though requires a little more camber than a +40 since it sticks out further) but is an aggressive fitment on the rear and without rolled fenders and some camber, you will likely get the occasional rub when you go over a big bump. Hope that helps, Mark
2011 BMW 128i - Check out my STX build thread!
05-24-2017, 07:31 AM | #11 |
Rep 11
This is great info, Mark.
I'm looking at a square setup that's 18x8.5 +38 on stock suspension. Based on what you're saying, it seems as thought this could work... or would I need the camber from a coil over setup? |
05-24-2017, 08:09 AM | #12 | ||
Rep 6,196
I am thinking of going with similar front coilovers. What length of front spring did you use to give you that clearance? 7"? |
05-24-2017, 08:30 AM | #13 | |
1Addict
3234
Rep 7,894
Damper tube clearance may require small spacers if using Ohlins.
05-24-2017, 07:41 PM | #14 | |
Rep 120
05-27-2017, 10:50 AM | #15 |
Rep 361
In my opinion, a 245-35-18 street tire is ideal on an 8.5" wide wheel. You could probably fit a 255 in most tires but I would not recommend it if you are choosing an ultra high performance tire such as the Bridgestone RE71R as they tend to run wide and it's even a little pinched on my 9" wide wheels.
