      04-02-2017, 11:04 AM   #1
beattiecj
beattiecj's Avatar
Drives: 2012 135i 2017 x5 35i 1988 e30
2017 200TW – Mixed Track and Street Tire Selection Help
Hi All,
As track day season approaches I am gearing up with new tires and wheels (EC-7s) and planning to run 235-40-R18 up front and 265-35-R18 rear. I will be on stock suspension with Carbotech XP10 pads, with plans to do coilovers at some point.
For 2017 there seems to be many new choices in the 200 tread wear ultra-performance tire selection.
Can anyone provide input on the following tires?
My requirements are to get close to 10K miles, 5-10 Track Days, not swap tires driving to and from the track and no fender modifications to get the tire to fit.
Brand: Bridgestone
Model: Potenza RE-71R
Brand: Dunlop
Model: Direzza ZII Star Spec, is there a newer version coming out?
Brand: Falken
Model: Azenis RT615K+ and RT615K
Brand: Hankook
Model: Ventus R-S4, I have left out the R-S3 as I cannot find it on Tire Rack and assume the R-S4 is the replacement.
Brand: Kumho
Model: Ecsta V720
Brand: BF Goodrich
Model: G Force Rival
      04-02-2017, 05:57 PM   #2
drunkenup
Drives: 2009 135i, 2021 F150
Word on the street is there is a Dunlop z3 next quarter or after. There is a leaked image of its tread pattern and contact patch improvement somewhere. I am very happy with my Z2 SS and they may still be running a rebate for them on tirerack. They run pretty wide and are very square compared to the rs4 which has tapered edges like the re71 now. Amateur testing reveals the rs4 a half second-second behind the rival S (and probably re71r).
beattiecj127.50
      04-04-2017, 04:47 PM   #3
Rudy@tirerack
Drives: rudy@tirerack.com
I would recommend the Hankook RS4 or Dunlop Direzza ZII Star Spec. These tires seem to have decent wear with great performance.
The Bridgestones are super fast but wear pretty quickly.
      04-04-2017, 06:08 PM   #4
tock172
Beachtown Bill Collector
tock172's Avatar
Drives: 2012 135i
2012 BMW 135i  [0.00]
1999 Lexus LS400  [0.00]
1985 BMW 325e  [0.00]
In terms of grip, I've found nothing can touch the RE-71R aside from dedicated R-compund tires. Yes, they wear extremely fast, but that's the common tradeoff for performance.
2012 BMW 135i Space Grey Metallic M-Sport DCT Dinan S2
      04-13-2017, 12:24 PM   #5
lowbudgethero
lowbudgethero's Avatar
125
Drives: '98 Z3M (gone), '09 135i
2009 BMW 135i  [8.50]
RE-71R are probably better with grip,
but Z2 star specs might be on sale soon if the Z3s come out
I personally have the Z2s and like them
      04-14-2017, 05:54 PM   #6
deesea
Drives: 2009 135i
are the ZIIs a squared off shoulder, or a rounded off one?
      04-14-2017, 06:04 PM   #7
lowbudgethero
125
it's pretty squared off, they are about 10mm wider than my old PSS, both 255
      04-14-2017, 08:01 PM   #8
Ginger_Extract
California-bound
Ginger_Extract's Avatar
Drives: BMW 135i
None of those tires are going to last 10 track days, unless you're just not pushing very hard. Of the bunch, get the Dunlops. They'll last the longest and have the best street manners.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18
https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3
      04-14-2017, 08:05 PM   #9
deesea
Drives: 2009 135i
Awesome. Thanks, I think the Direzza's are going to be my next set.
Perhaps a 225/255 combo since the tires are so wide and front fitments will be tight.
      04-19-2017, 04:11 AM   #10
geeyore
geeyore's Avatar
Drives: 2011 135i 6MT
I've run 235/265 RE-11 on Apex 8.5/9.5 EC-7 wheels but there was rub in some track corners. 225/255 were better with very little rub. Also Nexen SUR4 which are grippy but very noisy on the street. I was considering RE-71s, but another guy at the track pointed out to me the degradation on the tire surface of his RE-71's, and we speculated it was tire heat. Some people more knowledgable than me have called the RE-71 an "autocross tire" because of that, while others have said they're fine on track.
After a few years I've given up on finding the right street/track performance tire with the right fit. Pretty soon it'll be DOT R or slicks on separate wheels, hauled in the back at the moment, which brings up a new kind of fitment problem. So that's probably lead to a Hoyt hitch and "luggage" trailer.
2011 135i 6MT, Cobb FMIC, Stoptech ST-60, Pagid RS-29, Castrol SRF, Goodridge G-Stop, Apex EC-7, Dinan Front Sway, Ohlins R&T, Swift 400/500, Vorshlag Camber, M3 lowers & bits, Diffsonline 3.08 3-clutch, Sparco Ergo/Evo, Schroth Hybrid, RRT welded 4-point hoop
DD: BMW 328xiT Prior: 2000 323iT 5MT, 2000 Z3 2.3 5MT, 2001 325iT 5MT, 2009 128i 6MT
      04-19-2017, 06:31 PM   #11
Rallim
Drives: 2009 135i
Also another vote for the Dunlops. A few track friends have very good things to say about the Re-71's, and I found the old Rt-615s a little eh. Seemed the least sticky out of everything I've run for sticky tires
      04-20-2017, 03:19 PM   #12
beattiecj
beattiecj's Avatar
@geeyore
Thanks for the input.
Were you running any spacers and how much camber were you running with the 235s?
      05-03-2017, 11:04 PM   #13
Hops128i
Hops128i's Avatar
71
Drives: 2010 128i, manual, sport pkg
I have a dedicated track/autocross set of 245/40-17 ZII's. Although i have a 128i, i've done 40+ autocross runs and 4 track days (well 3 of those were track nights) and they still have a good amount of tread left. The ZII's are also ok in the rain. But i did have to roll the rear fender with 1.5 degrees rear camber.... probably wouldn't need to roll with 2 degrees.
2010 128i manual, sport package, performance exhaust, Vorshlag camber plates, Bilstein B6 struts/shocks, 245/40/17 ZIII square on et 40 with rolled rear fenders.
beattiecj127.50
1addicts
