12-30-2016, 05:19 PM | #1 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Best tire sizes for track wheels
There are lots of threads about optimal offsets, how much wheel/tire can be fit, etc... but this is a slightly different question.
Tire manufacturers provide an "ideal" or "measuring" wheel width for each tire size, and it seems reasonable to assume that the wheel width/tire size that matches the "ideal" would be the best choice... and for regular street driving, it most likely would be. But for maximum grip on track (assuming a fixed wheel width) would it actually be better to run a tire that's slightly narrower to stretch it a bit? A tire size for which the manufacturer indicates an "ideal" wheel that's 1/2" (or even 1") narrower? Here's an example of what I'm contemplating... On my car, I know that a 9.5" wheel is at the outer limits of what I can squeeze under the front fender, so I'm trying to figure out what would be best for a track-only wheel/tire setup - the options being:
For the best track performance on a 9.5" wheel, which tire size would you choose?
Ahead of the curve for specF30
12-30-2016, 05:32 PM | #2 |
Rep 818
I've always heard that you want a tread width that is the same as the rim width. Since some tires run wider or narrower than others, I think it depends on what tire. A 275 RE-11 has a tread width of 9.7 inches, same as a 265 RE71R.
12-30-2016, 06:46 PM | #3 | |
558
Rep 1,477
Drives: 335i
So for the RE-71R, the 265/35 has a tread width of 9.7" and the 255/35 is 9.3" - so they bookend a 9.5" wheel by 0.2" in either direction. In this case, better to go with the tread width a little wider, or a little narrower than the wheel width? Also interesting that the 255/40 has a tread width of 8.9", which is a sizable step down from the 255/35 *Edit to add: After some quick research, it looks like the tread width variances of a given tire size between various manufacturers goes beyond the tires being slightly different sizes. In some cases, the differences are huge, so I'm thinking different manufacturers measure tread width in different ways... which could really throw off the equation for some tires.
12-30-2016, 10:37 PM | #4 |
Rep 8,076
Drives: 11 E90 M3 Individual
You're fine if you stay between 255-275 wide tires on a 9.5" wheel. The 255s will look a little stretched.
2018 F30 320iX Melbourne Red
12-31-2016, 12:11 PM | #5 |
Rep 818
FYI, here's an article discussing this very topic:
http://www.motoiq.com/MagazineArticl...RFORMANCE.aspx |
12-31-2016, 01:43 PM | #6 |
Rep 6,218
Also these manufacturers sand bag their specs.
01-02-2017, 11:53 AM | #7 |
Rep 938
the standard for the e92 m3 is a 18x10" wheel. why do you want something more narrow? i think stretching the tire too much is too risky. also, agree that the tires are not spec'd very accurately.
as an example - I have my x5 summer tires stacked next to my track tires. x5: 2 315's and 2 275's. track tires: 4 275's. guess which is taller? lol. |
01-03-2017, 12:38 PM | #8 |
Rep 14
I am from Miata world, we hair dressers completely ignore factory recommendations.
we run 205 Hoosier (which is as wide as most 225) and most 225 on 9". and 245 on 10". 275 on 11" and YES, we've done test and can assure you 205 Hoosier is faster (track) on 9" than 8", which is faster than 7" this is for track. not street recommendation. |
01-03-2017, 01:29 PM | #9 |
Rep 818
I missed this part of the post in my response. Most of us run an 18x10x25 square setup for the track with 275/35 or 265/35 tires. So a 9.5" wheel would not be maxing out your capacity in the front fender. Even if you wanted to go with a staggered setup, you could still run 10" front and a 10.5" or 11" rear.
scotty_miller184.50 |
01-03-2017, 04:55 PM | #10 | |
Rep 938
Curious - why do you need 275? |
01-03-2017, 05:34 PM | #11 |
Rep 14
because they don't make a 305 in 15"
autocrossers love 275.... for tracks, some turbo Miata also run out of tires with 225 or 245... aren't you surprised M3 use such a narrow tire for a 3600LB car ? if a 3,200LB Vette can take advantage of 305..... Last edited by Bellwilliam; 01-03-2017 at 06:01 PM.. |
01-03-2017, 07:45 PM | #12 |
Rep 938
I'd like to fit a 305 around (can squeeze into the rear but not worth the lack of rotating for even wear). I didn't think a Miata would benefit from such a wide tire. Sweet
01-03-2017, 08:22 PM | #13 |
Rep 5,483
I've often thought a pretty hot setup for this car would be a 19x11 with a 305/30-19 in back and 18x10.5 with 295/30 or 285/35 up front. Would need some minor fender liner massaging to fit but takes full advantage of the available space. And there are just tons and tons of factory fast cars with staggered diameters so it's not the craziest idea. There aren't many good 305+ rear tire options in 18" for these cars but tons of 19's. You could do it relatively inexpensively without taking a big weight hit if you use TE37SL's
01-04-2017, 07:08 AM | #14 |
Rep 259
I have been running a 18x11 et44 with 12mm spacer in the rear with a 305x35x18 NT01 tire. The front tire is a 275x35x18 front on a 18x10 et25 wheel. I plan to try to fit a 315x30 in the rear mainly because I want a shorter (smaller diameter) tire. The extra tire definetely helped to keep the rear of the car planted but the price you have to pay is tire wear.
In order to fit the larger rear, I had to remove the wheel well liner and grind off a little bit of seam sealer. |
01-04-2017, 04:01 PM | #17 |
Rep 5,483
Hoosier A6 - that's a 295/30-18 up front too, this is on stock '08 springs and 8.5/9.5" wheels at stock offsets; there was lots of room around the tire in back and so I think they would fit comfortably on a 10.5" wheel and an 11 with the right 30-ish offset would probably work too. There was no rubbing anywhere. One day I will be stupid enough to go super-wide in back again but not today; car's street only now and the widest I'll probably ever do is a 295 in back. Obviously Hoosiers respond differently to pinching than street tires do, but we know from other people on this forum that a 295/30-18 on a proper 10.5" wheel will work up front as well and there's way more room in back, sooo... Last edited by Richbot; 01-04-2017 at 04:19 PM.. |
