BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      10-23-2016, 10:56 AM   #1
8600RPM
Drives: e92 m3
Best diff fluid without friction modifier?
All oem diff fluid has the friction modifiers in it and I'm looking to get the most performance and not a,quiet diff so looking to change it. Can't find castrol syntax 75-140 anywhere which is what oem uses. Do they still make this or any other recs?
      10-23-2016, 11:07 AM   #2
Datka
Datka's Avatar
450
Drives: 2009 M3 ,2021 M340i
Here we go
https://www.carpartsdiscount.com/dif...ml?3593=545783
I got it in a Mercedes dealership when I changed mine.
"Racing is life. Anything before or after is just waiting." Steve MCQueen
      10-23-2016, 09:11 PM   #3
roastbeef
roastbeef's Avatar
Drives: E92 M3
is there any reading or experiences to share that this actually increases performance? i'm interested.
Instagram; @roastbeefmike
      10-23-2016, 09:29 PM   #4
Datka
Datka's Avatar
450
This is from another thread:
3. Change the diff oil to the standard Castrol diff oil without FM booster.
I changed mine recently, draining out the BMW oil with extra FM booster and replacing it with Castrol SAF-XJ 75w-140.
The benefits are that the tendency for the less loaded rear wheel to spin up is reduced or eliminated.
A big reduction in the TC light coming on.
Less instability in rear grip under hard acceleration.
In MDM the diff locks up much quicker rather than one wheel spinning up causing the TC to kick in and reduce power.
Diff oil history:
E46 M3:
Factory OEM fill was Castrol SAF-XJ 75w-140
BMW produced their own packaging containing Castrol SAF-XJ 75w-140 with extra FM additives only for customers who complained of noise.
E9x M3:
Same as E46 except (my dealer tells me) sometime around 2010 the BMW Castrol oil with extra FM became the OEM fill.
About the same time Castrol SAF-XJ was rebadged as Castrol Syntrax Limited Slip 75w-140.
Note that the Castrol diff oil above already contains friction modifying additives.
The additives have to allow easy slip between the clutch plates without judder over a large oil temperature range yet lock up completely when clamped together at full operating pressure.
At some tepid temperatures however the additives struggle to allow the clutch plates to slide smoothly over each other and the resulting "slip/stick" effect is heard as a light groan when cornering. This is considered to be a normal function of a high performance LSD. Adding more FM additives to the diff oil (as in the BMW repacked oil) will quieten the diff at the expense of raising the clamping pressure at which the clutch plates are fully locked against each other....IOW the clutch plates slide easier over each other which allows more single wheel spin up and delays the locking action of the Diff when rear tyre grip is lost.
If you do switch to standard Castrol diff oil and find that the diff becomes too noisy (mine is still quiet) then you can either add some concentrated FM (from Opie for instance) or just drain and refill with the BMW oil.
roastbeef11586.00
M3MPH1S592.00
      10-23-2016, 09:38 PM   #5
Killerfish2012
Drives: E90 335I, E92 M3
Run royal purple 75W 140. It's the best there is.
'07 335I w/ Mods
'13 X1 Stock
'11 X3 K&N
roastbeef11586.00
M3MATT91.00
      10-23-2016, 09:49 PM   #6
roastbeef
roastbeef's Avatar
Drives: E92 M3
thanks for taking the time to find that. will any 75w140 without friction modifiers work? like if i wanted to do research on other specific brands?
      10-23-2016, 11:58 PM   #7
Rassilon
Drives: 2011 e92 m3
I always feel the m diff to be laggy when accelerating hard, maybe the FM are the reason? I used dctf-1
      10-24-2016, 08:29 AM   #8
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
If this is for the track, why are people running DSC or MDM on? First improve your driving to turn it off. That'll get you better performance. Is this some kind of workaround to leave it on?
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
AriuSen776.50
      10-24-2016, 08:56 AM   #9
italyix
italyix's Avatar
Drives: '08 E90 M3
Until the purple pigment decides to coat all your components.
I use redline 75-140 without the modifier in my diff and have no complaints thus far. Also use redline in engine and transmission, 0-40 and D4ATF
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782
amg6975500.00
      10-24-2016, 09:14 AM   #10
dparm
Stop the hate, get a V8
dparm's Avatar
Drives: C7 Corvette GS, AMG C63 S
Before you go putting a non-FM fluid in, check out my thread on BITOG about this very thing:
https://www.bobistheoilguy.com/forum.../against_FM_in
The OEM fluid is Castrol SAF-XJ (now called Syntrax LS) but it has extra friction modifier. If you want the version with "normal" FM dose, the Mercedes fluid is that. ECS also sells the Castrol-branded version.
Past: 2011.5 M3 sedan ZCP
      10-24-2016, 09:28 AM   #11
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
I was thinking of dumping the factory fill (version with FM) that I put in 2 years ago for Redline Heavy Shockproof. I can light up my 285/35/18 PSS way too easily and I am just modded N/A. But maybe the fluid won't make any difference?
      10-24-2016, 09:41 AM   #12
dparm
dparm's Avatar
I wouldn't use Heavy Shockproof. Those are weird fluids and I've yet to hear Red Line ever conclusively recommend it for a street car.
I would stick with an LS-specific 75w140. If you want less FM, just get the normal version of Castrol Syntrax LS 75w140.
      10-24-2016, 09:42 AM   #13
dparm
dparm's Avatar
Speed sensitive LSDs are not known for their fast-locking.
Also, DCTF-1 is the dual-clutch transmission fluid. It's basically a 75w85 with some extra additives. You should NOT be using that in the rear diff!
      10-24-2016, 10:12 AM   #14
warp10
warp10's Avatar
776
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
2011 M3  [10.00]
2011 28i X3  [0.00]
been using the motul stuff and its great
///Mobbin1478.00
      10-27-2016, 09:50 AM   #15
dparm
dparm's Avatar
There are three Motul 75w140 gear oils. Which one are you using?
Gear Competition LS
Hypo Synt LS
Nismo Competition Oil 2189E
      10-27-2016, 03:29 PM   #16
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Gear Competition LS
Hypo Synt LS
Comp the first one
      10-27-2016, 05:40 PM   #17
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
Redline makes a 75w-140NS which has no FM in it.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      10-27-2016, 06:38 PM   #18
roastbeef
roastbeef's Avatar
Drives: E92 M3
So who has used one of these oils without FM that tracks and noticed a difference?
This isn't the same feeling that people think they feel between different brands of the same oil weight?
      10-27-2016, 06:55 PM   #19
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
You can just buy the Castrol OEM fluid without FM. It's much cheaper too.
https://www.ecstuning.com/News/BMW_E...l_Fluid_20651/
Auto Detailing Enthusiast!
      10-27-2016, 06:57 PM   #20
Z K
Z K's Avatar
1889
I'm running the fluid without FM. I don't really notice a difference on track. I get a clunk now and then when the diff is cold and I'm turning while parking.
roastbeef11586.00
      10-28-2016, 11:31 AM   #21
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
This is what I use
      08-21-2023, 10:01 AM   #22
kolosy
Drives: over potholes
resurrecting an old thread, sorry. i was going to change my diff oil (and replace an output shaft seal while i'm in there), and realized that i have 2 bottles of LM GL5 75-140 sitting in my closet (left over from my M Roadster). Any issues with using that, or should I buy something else from ^?
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3
I think I have an M3 problem.
m3post
