09-23-2016, 12:43 PM | #1 |
Rep 699
M lap timer integration with GoPro
In a recent issue of the BMW CCA magazine it said that the latest version of the M lap timer app now allows integration with GoPro, eg starting and stopping the camera together with the lap timer etc.
Has anyone tried this and got it to work? |
09-23-2016, 05:59 PM | #2 | |
Stop the hate, get a V8
3851
Rep 8,625
Is that for NBT? I know there is a GoPro app for the car, but I don't think it's for CIC.
Past: 2011.5 M3 sedan ZCP |
09-23-2016, 06:58 PM | #4 |
Rep 599
10-01-2016, 02:22 PM | #5 |
Rep 154
Could you post a screen shot from a regular drive showing the speed and motor rpm's for me ?
I have the strangest laptimer log files that show that the motor/drivetrain is slipping and the clutch is dumping but I have nothing to compare it to. Other then the examples from the laptimer of course and they look like I think they should look. I have a 2011.75 dct. I would appreciate if you could post a screenshot showing a acceleration and gear change. Thanks in advance. |
05-06-2017, 07:00 PM | #6 |
Lord Scrip
1815
Rep 3,013
Drives: 2011 M3 Coupe
Incorrect bud. It works on E90 W/combox.
05-06-2017, 07:01 PM | #7 |
Lord Scrip
1815
Rep 3,013
Yes. 2011 E92 M3 CIC w/Combox iPhone 7
05-08-2017, 11:49 PM | #8 |
Rep 9,032
Could you explain how this works?
I've used the Lap timer a few times. It's not great but it's free. How do you combine the GoPro video with the laptimer data? .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
05-09-2017, 12:01 AM | #9 |
Lord Scrip
1815
Rep 3,013
iPhone 7 with connected drive app and GoPro capture app. Successfully connect your GoPro to the capture app on your phone. After that your phone can connect to GoPro once it's on at any time. Then if you open the mlaptimer app it will recognize you camera. Since this is the iPhone 7 and I have CIC, I had to purchase the BMW Y media cable. Then I was able to see the GoPro images on iDrive while stationery. Once you start driving the displayed image goes away even though I have video in motion. You can start and stop recording, display gforce data, display recorded track route all on iDrive screen.
aus891.50 |
05-09-2017, 02:06 AM | #10 |
Rep 9,032
Thanks for the explanation!!
I never would have figured I needed a Y cable.
05-10-2017, 01:59 PM | #12 | |
3851
Rep 8,625
Probably pretty slow -- I'd guess 1 or 2Hz. If it were 5, I would be surprised.
05-10-2017, 04:25 PM | #13 |
Lord Scrip
1815
Rep 3,013
I don't know about that. You can start stop recording, you get great data, all apps are free that you need for this. I'm sure it's not a great idea but you can start and stop recordings while driving from iDrive which is awesome to compare lap times. Like you guys said I'm sure there is a higher latency on the data but for free, I think it's a great tool for anyone playing on the track.
05-10-2017, 08:22 PM | #14 |
Rep 599
I use both Harry's with my 5hz GPS, and the BMW Laptimer, the two are very close in times... You just have to make sure the start/finish points are synced between the two apps for a good comparison.
02-22-2022, 05:04 PM | #15 |
Rep 52
There is another option for those who want telemetry and video and want to spare some bucks (my case). Recently, I've put together some code to use a GoPro as video and GPS along with the MLaptimer app data. It is very straight forward to use, no need for wiring into any ECU neither pairing different devices via bluetooth. All you need is to go out on the track while recording with the GoPro and with the MLaptimer app. By the way, the MLaptimer for iPhone is a really cool app, specially if you consider that the car sensors (but the GPS) are very accurate.
The code I've put together will parse the MLaptimer low res GPS track with the high res GPS track from the camera, sync everything together, and output a csv file for rendering videos with Dashware or RaceRender. Even better, it also outputs a .vbo file, which can be used in CT to analyze the driving, with very good quality (of course, quality depends on how good you set up the GoPro). Check the results below and access www.easy-telemetry.com to know more. Note: processing the app files is free, but there is a little fee for processing GoPro files. |
02-23-2022, 08:59 AM | #16 | |
Rep 3,409
Not a Doctor, those are just my initials.
04-08-2022, 10:46 PM | #18 |
Lord Scrip
1815
Rep 3,013
It's always worked. Not many folks use it
