09-15-2016, 06:39 PM | #1 |
Rep 400
When do you upgrade tires?
I do a couple open lapping track sessions per year. I have a set of ZCP's with stock PS2 tires that I use for these sessions. I have a different set of wheels for daily driving. First time out this year I trashed my front brakes so I purchased a set of PFC08's for all four corners and changed to SRF fluid. My next session out with the upgraded pads I felt like my tires were the weak link in the braking zones. Seemed like there was more tire chirping while braking (I try to stay above ABS but lack the experience to not make these mistakes). Is it possible that the tires can't keep up with the brakes?
When do you upgrade to a stickier set of tires? I'm thinking in terms of the Hankook RS3, RE71's or AD08R. |
09-15-2016, 10:28 PM | #3 |
Rep 2,672
For the tires you are talking about I would go ahead and upgrade on the next set, may as well use up the PS2's first though.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
09-15-2016, 11:54 PM | #4 |
Retired Curmudgeon
2985
Rep 4,047
PS2s suck. RE-11s are a step up as are PSS'. RE71r's are a huge leap.
You should go to a stickier tire when you can controllably and repeatably 4-wheel drift the car (not hang the tail out, I'm talking a fast lap). Until then the sticky tires will just mask errors you make and your learning curve slows down. Plus, with stickies you hit stuff faster when you really f'up.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
09-16-2016, 11:21 AM | #5 |
Rep 699
You will get a lot of opinion on this, see this thread for example.
http://www.m3post.com/forums/showthread.php?t=1278796 From what I've read the problem with PS2 on the the track is not the performance but that they can wear quickly once you lean on them; some folks report seeing cords after a single weekend. So something with stiffer sidewalls might be a good direction. Also, many track-oriented tires are cheaper than the PS2... This year I am trying Nitto-05 tires for the track and so far I really like them; my experience has been much as described by Longboarder in the above thread. Good luck, there are many nice choices out there.. |
09-16-2016, 11:48 AM | #6 |
Stop the hate, get a V8
3850
Rep 8,625
I would upgrade tires as soon as your technique is good.
Past: 2011.5 M3 sedan ZCP |
09-16-2016, 09:26 PM | #7 |
Rep 12,728
Got my track set of wheels after my first track day when I knew I was addicted. They came with nt01's and guess what...
Instagram; @roastbeefmike
09-17-2016, 11:04 AM | #8 |
Rep 400
I definitely don't get my car sideways or in a four wheel drift. Too many off camber corners with concrete walls in play at Mission Raceway to risk it. I keep traction control on all day and yes, it seems to intervene coming out of most corners.
09-17-2016, 11:06 AM | #9 |
3850
Rep 8,625
Try Euro MDM. Perfect compromise. The only time it really cuts in is if I'm not driving smoothly.
09-17-2016, 01:08 PM | #10 |
Rep 1,140
Drives: Something something racecar
No DSC or bust. I tell everyone now that they should turn off traction control ASAP. Too many benefits.
SYT_Shadow11490.00 |
09-19-2016, 05:08 PM | #11 |
Retired Curmudgeon
2985
Rep 4,047
Everyone's risk tolerance is different. Euro MDM allows enough slip to still be fun. You can't go as fast as with DSC off but it's not an epic difference. If there are a lot of "that won't buff out" opportunities I completely understand running some form of DSC. however, DSC does not guarantee a spin or crash free day. You can crash with DSC on. Seen it.
09-19-2016, 06:16 PM | #12 |
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
I found that with RE-71R that's Euro MDM was not nearly as intrusive than with NT01. It was cutting all over the place with NT01, to the point that I just went full DSC off at that point.
Also, even stock Euro MDM (no modifiers) is really punishing at a track like Laguna Seca where the final turn 11, if you are on the throttle too early for its taste it will cut your power for a good 2-3 seconds, where as with DSC off, you slide a little bit and are on your way. |
09-20-2016, 12:27 PM | #14 | |
3850
Rep 8,625
Odd, I've never had Euro MDM need to intervene for several seconds at a time. The DSC light will flash briefly if I do something really stupid, but it is never holding me back for more than a fraction of a second.
09-20-2016, 12:51 PM | #15 |
Rep 2,527
Neither did I until Laguna Seca. It was weird.
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
09-20-2016, 03:59 PM | #16 |
Rep 1,140
E46 DSC is more intrusive than E9X. I can instantly shave off 5 seconds at any track after disabling DSC.
09-23-2016, 12:19 AM | #17 |
Retired Curmudgeon
2985
Rep 4,047
Hmmm...throttle modulation much?
I had euro mdm on w/NT01s at Laguna during O'Fest and I can't recall an issue with throttle cutout at 11. Opposite lock had to be added sometimes as the back end would step out a bit. I used this tendency to allow me to early 11 a bit and still get the car around the corner without running out of curbing on exit.
10-08-2016, 04:00 PM | #18 | |
Rep 8,076
Drives: 11 E90 M3 Individual
Too many people weenie out and don't drive in the wet because they can't set fast lap times.
2018 F30 320iX Melbourne Red
10-09-2016, 02:38 PM | #19 | |
3850
Rep 8,625
I've had a weird stroke of luck that NONE of my track days this season were in the wet.
10-09-2016, 02:43 PM | #20 | |
Rep 465
I have seen a lot more crashes with DSC off vs DSC on. I drive with euro MDM on, but sometimes I turn it off just to see the difference. Depending on the track, its between 1 and 2 seconds. Car is faster with DSC off of course.
"Racing is life. Anything before or after is just waiting." Steve MCQueen
10-10-2016, 11:04 AM | #21 | |
Rep 742
2011 Jerez Black/Fox Red E90 M3 DCT, ZCP, ZCV, ZCW, ZP2, BMW Apps
2015 Golf R |
10-12-2016, 10:37 PM | #22 |
Rep 9,032
If Euro MDM is cutting your power for a couple seconds, it really doesn't like what you're doing with the throttle or steering wheel/throttle combo. I read here that it takes into account the steering wheel angle, slip angle and throttle to help determine when the cut power or brake. I found it's much less intrusive if I open the wheel up a little more with throttle application; it seems to work well. At O'Fest, I did my first 4 wheel drift going around 5 and a little around 6 with no MDM lighting up. That was butt clinching fun!!
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
