08-24-2016, 10:52 AM | #1 |
Rep 4
128i 16" winter tire fitment question
I have a 2009 128i 6MT base edition.
I was looking for a winter tire setup and came across this setup locally from a 2007 328i Wheels: Sport Edition A12 16X7.5, Offset 35mm Backspacing 5.708 Bolt Pattern 5X120 Tires: Goodyear Blizzak LM32 (205/55/R16) I currently have 17X7 inch OEM setup.(Style 256) Will these fit the car without any modifications? Is there anything I should be worried about? Have done some searches already but haven't found a concrete answer yet. |
08-25-2016, 09:57 AM | #3 |
Rep 1,233
They will physically fit, the issue is if you will have rubbing or not. From your stock to these, you are losing about 2.5mm space in your wheel arches since the new wheels have a bigger overall diameter, and you are also going to have wheels that will poke almost 20mm further outward from the current wheels.
That means there is greater chance of contacting the fender/body panels on full compression of your suspension. I would guess with base/non sport suspension, you won't really have any rubbing unless you have horrible roads and drive through massive bumps all the time. The other thing is visually the new wheels will stick out more by almost 20mm each, so they may look a bit funny is all. Use this site to evaluate wheels/tires: http://www.willtheyfit.com/index.php...t2=35#isPage=1 |
skhan0.00 |
Tags |
128i, fitment, winter |
