08-21-2016, 01:31 AM | #1 |
Rep 1,140
Drives: Something something racecar
How often do you replace your studs and lug nuts?
I'm getting tired of using lug bolts, and it may be time to convert to a stud kit. Studs break and lug nuts stretch over time, I've read/been told. APEX recommends that both studs and lug nuts be replaced annually on a track car, but I was wondering what interval(s) actual users follow. When ordering, should I purchase 1-2 extra studs and/or lug nuts just in case of unexpected failure?
08-21-2016, 01:55 AM | #2 |
Rep 12,728
I'm getting close to two years on mine. I'm going to be proactively changing mine soon. Had turner's, ordered four extras. None broke.
Instagram; @roastbeefmike
08-21-2016, 06:39 AM | #3 |
Rep 1,848
I think every two years is reasonable. I see some folks checking torque before every session. In my experience my lugs stay properly torqued through the weekend, so I only check in the morning. I think constantly torquing these fellas leads to early failure. YMMV.
08-21-2016, 11:25 AM | #5 | |
Rep 8,076
Drives: 11 E90 M3 Individual
Just takes a light pull to get a click. Once the fastener turns...you're adding torque.
2018 F30 320iX Melbourne Red
nholmes542.00 |
08-21-2016, 12:53 PM | #6 |
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
I had to replace mine after about 20 track days, or 7 months. It all depends how much use you put on, TBH. One of mine snapped after 20 and that's all she wrote. I'm not abusive on torquing them either.
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
nholmes542.00 |
08-21-2016, 06:16 PM | #8 |
Rep 6,218
I do it annually now just bc of breaking things before. They're not expensive so better safe than sorry. That's just me though.
But I see a lot of ppl looking to buy used ones who don't think cal. Maybe I'll put them on the for sale forum LOL
08-21-2016, 07:48 PM | #9 |
Rep 12,728
i'm not sure if it contributes or not, but i like to let them cool before i mess with them. if i'm swapping wheels at the end of the day, i'll be sure to get a generous cool down lap in, and then let the car sit for a little bit. i just feel like torquing to tighten/loosen when hot might not be healthy for them.
redpriest2147.00 |
08-21-2016, 08:45 PM | #10 |
Rep 1,679
I replace annually. Definitely a bad idea to torque them while hot.
08-21-2016, 09:18 PM | #11 |
Rep 12,728
while on the topic of studs, has anyone used the expensive turner "dry lube" race studs?
https://www.turnermotorsport.com/p-3...-e9x/Checkout/
08-22-2016, 08:31 AM | #12 | |||
Rep 1,140
Cool. I'll start at 2 years and adjust if necessary.
I stop right when I hear the torque wrench click. For proper use, is there more to it than just that? Quote:
08-22-2016, 08:36 AM | #13 | |
Stop the hate, get a V8
3850
Rep 8,625
Same. I don't understand why people feel the need to check torque after every session. In fact, I don't really want to be re-torquing stuff when the hubs, nuts, and everything else is extremely hot AND at ambient temperature. I have never checked the torque and found them to be loose.
Past: 2011.5 M3 sedan ZCP |
08-22-2016, 02:17 PM | #16 |
Rep 2,527
I've never done it. Red loctite + torque them down = no worries.
macdude357467.00 |
08-22-2016, 02:41 PM | #17 |
Rep 1,679
08-22-2016, 03:40 PM | #18 | ||||
Rep 8,076
If you want to be super anal retentive then you'd torque to about 90% and then do a final torque to 100%. I don't even use a torque wrench. I use a 80ft lb torque stick on a Milwaukee 18v battery impact. Squeeze the trigger and keep going until the nut stops turning. I've check it enough to know I'm right around 80 ft/lbs. This is assuming that the mating surfaces on your wheels and hubs are clean and you've properly seated the wheel flush against the face of the hub.
08-22-2016, 05:10 PM | #19 | |
Rep 12,728
i'm looking at this one. https://www.amazon.com/STEELMAN-5009...s=torque+stick
08-22-2016, 05:18 PM | #20 |
Rep 6,218
i think blow torch will take care of it. unless red means you can't even fire it off lol
08-22-2016, 11:07 PM | #21 | |
Rep 1,711
