BMW M3 Forum (E90 E92)
BPM
      08-20-2016, 11:05 PM   #1
elim11
Drives: e90m3
Stripped oil drain plug!
Sucks big time. I was chugging along just laughing at myself at how easy our oil changes are. Was on world record pace to finish and the unthinkable happened. Went to tighten and it just spun.
I am not confident in my ability to fix it so I will most likely be towing it to MRF on Monday morning. Is this an easy, cheap fix. I was hoping to go to acs in Sept and hope this doesn't put a large dent in the wallet.
Is there any recommended upgrade while I'm getting this fixed? Maybe like a baffle etc?
      08-21-2016, 12:27 AM   #2
Kong Sheng Han
North Korea
303
Drives: Something something racecar
2011 BMW 328i  [0.00]
2001 BMW M3  [0.00]
I use this on my E46. You may be able to use it on the E9X as well. I like having the hex head as a backup, and I now replace the plug every oil change to reduce chances of stripping.
https://www.ecstuning.com/b-genuine-...g/11131742994/
M3MPH1S592.00
      08-21-2016, 01:25 AM   #3
elim11
Drives: e90m3
I should have clarified. Not the plug. But the oil pan I bought a new plug at the dealer to be sure and it's the pan
      08-21-2016, 06:40 AM   #4
ThunderMoose
Drives: PY E46 M3 and SG E46 M3
while you have pan off, how about replacing rod bearings?
      08-21-2016, 09:05 AM   #5
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Is It leaking now? If you have finished oil change and it isn't wait until next oil change and take it in. I actually did 2 separate oil changes on e46 with a punch and hammer to get out oil and recap.
      08-21-2016, 09:39 AM   #6
///Mobbin
///Mobbin's Avatar
1478
Drives: m3
Pretty sure you can re-tap it to a larger bolt size but not positive. Good luck and let us know how it goes.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
      08-21-2016, 09:43 AM   #7
///Mobbin
///Mobbin's Avatar
1478
Drives: m3
Fwiw, this is my new drain plug of choice after stripping a few of the soft OEM BMW drain plugs, LINK. Remember to buy 2 at a time, I also like to keep spares around.
M3MPH1S592.00
      08-21-2016, 10:23 AM   #8
UPSROD
Drives: 2013 E92 M3
2013 BMW M3  [10.00]
Time-Sert!
M3MPH1S592.00
      08-21-2016, 10:26 AM   #9
redpriest
redpriest's Avatar
2147
Drives: 2011 M3/Porsche 992 GT3RS
I did the same exact thing you did, stripped the oil pan. I managed to fix it myself with a Time-Sert. The oil pan was stripped so bad that about a quarter of the sidewall of the threading was missing - you could see all the way into he pan.
I'm not a clever man, but by watching videos and by having enough guts to give it a try, I tapped the stripped plug drain myself and installed it no problem. Used blue oil resistant loctite on the insert too.
It's cheap and easy. The expense comes if you don't have the required time sert kit to begin with ($100)
      08-25-2016, 10:53 AM   #10
elim11
Drives: e90m3
Got it all squared away by Malek @ MRF. Whew, was able to get it time-sert. He Time-sert both drains to prevent this from happening in the future.
redpriest2147.00
      08-25-2016, 03:46 PM   #11
ayao
Thread killer
643
Drives: 1M
Never knew such a thing existed!!
m3post
